Question about Optoma Televison & Video
Alll functions work of my remote controle except the functions backward / forward
  • 20 Answers
There some hardware related issue so get in touch with hardware person.
Posted on Mar 16, 2011
My dstv remote works well except the pause / fast forward / rewind
It sounds like a contact fault to its buttons inside the remote control. Your remote control need to have cleaned. To clean it, you have to open it and take the printed circuit board inside it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
One among the post by this site have details about how to clean and check a remote control. Surf the site with patience.
Mar 21, 2014 | Televison & Video
Should ceiling fans work "forward" or "backward"
During the winter you want the fan to blow downward so that the heat that collects at the ceiling is circulated,
Nov 20, 2010 | Universal Remote Control Hampton Bay...
Dish network code for a viore, volume/power not working
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 05, 2010 | Toymax Viore 42 in. Plasma TV
Will not change slides forward/backward, remote focus ok,
Your problem is most likely caused by a broken wire under the control panel or a wire somewhere in the "cycle circuit" that is no longer connected. You should seek out a factory-trained repair dealer who has a schematic that can trace down your projector problem.
Mar 15, 2009 | Kodak 4200 Slide Projector
Remote
Have you connected the USB Cable with computer to opearte mouse?
Viren
Jun 27, 2008 | Sharp XR-10X Multimedia Projector
3.1 IR Dish remote doen't work right
I would suggest to open the remote and clean the contacts very gentle using rubbing alcohol. If the cleaning does not work, it means the remote keypad is not longer functional.
May 30, 2008 | Universal Remote Control Dish Network...
Additional dvd features (scan forward/backward, display) won't work
It may not be possible with that remote. If you lost the original then consider a new one at:
http://www.replacementremotes.com
Feb 29, 2008 | Philips Magnavox Learning Universal Remote
Remote control code
Dish Netork does not have the code for Olevia
but you can scan for the code using the infformation
here
Remote Code Power Scan
If your brand is not listed, use the following procedure to scan through all codes.
If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
1. Turn ON the unit you want to program the remote to control.
2. Press the Mode button on the remote until the appropriate mode light is flashes
3. Press the Address button. The mode light will start flashing slowly.
4. Press the Power button. The mode light will stop flashing and stay lit.
5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8. Turn the device back ON by pressing the Power button.
9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10. If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Nov 23, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
67 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
