My hotpoint wt741 washing machine hsa stopped doing full cycles and flashes an error message F-02
    Brigadier General:
  • 6,277 Answers
'F02' for Hotpoint/Ariston and Indesit (who makes them) decodes as 'motor jammed/tacho detached: check motor and module connections'
The good news (probably) is that often these faults are cured by disconnecting the module (PCB) cables/plugs and reconnecting again, a fairly swift operation. I suppose the bad news is that you will need a service engineer to carry it out?
Hope this helps. and good luck!
John C
Posted on Mar 16, 2011
Hotpoint wt741 1400 spin-f-05 flashing on display board not empting or finishing wash?
Error code F05 means pressure switch jammed on full
Remove lower rear cover of washer.
Remove large black hose on bottom of tub.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstrucrtion here as well.
This should solve the problem.
PLease rate my solution.
Thankyou.
Jan 17, 2010 | Washing Machines
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Locate and remove large black hose fastened to drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
F03 error message on Hotpoint WT741
Error F03 indicates that the wash thermistor is open or short circuit.
Check the thermistor, heater and connections.
Hope this jelps.
Jan 09, 2010 | Washing Machines
MY WASHING MACHINE STARTS A WASH CYCLE THEN SUDDENLY STOP AND STARTS FLASHING F-02 WHAT DOES THIS MEAN?
Hi.
Error code F02 is a problem related to the motor.
It means that the motor is jammed, or tachco detached.
Check connections on motor and module, and motor plug.
Please rate my solution.
Thanks.
Nov 12, 2009 | Hotpoint Aquarius WD640 Front Load...
My hotpoint washing machine wt741 wont stop flashing
Hi Donna, did you fix this? Am guessing you have by now one way or another but have posted a suggested solution for someone else: http://www.fixya.com/support/t3268817-hotpoint_wt741_when_power_button. Worked for myself and one other poster on here.
Jun 23, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpopint Washing Machine WT741 flashing F-12
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Open Questions:
Maytag Bravos MVWX700XL2 won't spin the clothes and is making a weird whining/whirling noise when attempting to do so. Hi, I have a Maytag Bravos MVWX700XL2. It's about five years old. For about a year now, it would occaisinally make a weird noise while washing that seemed to come from the agitator working. I know this sounds funny, but the noise sounded like a chittering squirrel. It didn't do it all of the time, just mostly when I would wash smaller loads. Today I noticed while doing the weekly laundry, that the agitator wasn't fully agitating. It was turning back and forth, but very slowly and not "mixing" the clothes like it usually does. I went though two loads like that, and on the third load, when it was time for the washer to rinse and spin, it started to make a whining/whirling noise and it would not spin out the clothes (but it did drain). The control panel is not giving an error code. I removed the wet clothes and tried to have it just rinse and spin or drain and spin empty and the strange noise continued w/o any success. I have a video of it making that noise that I can post/send if someone can tell me how. I paid over $500 for the washer, and I really don't want to have to replace it this soon, nor do I want a $300 repair bill. My husband is very handy and could fix it if we knew how to properly diagnose the problem so we get the correct part. Based on what I've read, could it be the shift actuator or a broken motor coupler?
Jul 16, 2018 | Maytag Washing Machines
Washing Machines Logo
229 people viewed this question
Top Washing Machines Experts
