Question about Dishwashers
GE GSD 2200 Dishwasher doesn't fill
The motor humms and runs through the cycles but no water fills. The water valve is open and I've tapped on the float mechanism, but no change.
  • flaimee Oct 20, 2008
    My dishwasher puts water in, stops for a minute or 2 and then has error C5. It won't drain back out no matter what I try.
  • 1003 Answers
SOURCE: Ge Dishwasher GSD 2000z
REPLACE TIMER CONTOL BOARD
Posted on Feb 02, 2008
  • 1314 Answers
SOURCE: GE Dishwasher GSD 4130 Y01WW skipping cycle
i beleive your right id change the timer
Posted on Feb 26, 2008
  • 1314 Answers
SOURCE: dishwasher will not start
hello there im on ss too so i have a soft spot for any one who's trying to live on it first the problem can be any one of the things you mentioned there is no magic bullet that i can just say this is it your problem your neighbor will have to test but i will be happy to assist one of my instructors once told me appliance repair is easy you find out where the power starts you find out where it stops in between those two points is the problem first place to check is the breaker make sure its on that's where it starts then remove the lower kick-plate and check where the power hooks up under the washer from there it goes up to the door latch switches from the door latches it goes out to the timer from the timer it goes to the water valve safety switch then to the water fill valve then to the main motor now even if the timer motor was bad it still should fill when you turn the timer to start some where on the washer is a tech sheet which showers the switches and wiring diagram may be under the bottom kick plate but first check the breaker if its tripped turn reply to be and we will go from there just reply to this post and hold my rating till we fix it ok
Posted on May 09, 2008
  • 52 Answers
SOURCE: Corrected serial # on Nautilus dishwasher
Ok, great! I found the correct part for your model number. To view the pump/motor assembly, click here. Hope this was helpful.
Posted on Jun 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: Dishwasher cycles with timer, won't fill with
Remove the toekick plate on the bottom of the dishwasher.
Remove the wires from the water valve. Insert the leads from a volt meter into the water valve power wires.
Turn the washer on. After the initial pump out cycle the timer sends power to the water valve through the water level switch. If you get power to the wires,the water valve is bad or you have no water supply to the valve.
If you get no power to the wires the water level switch is bad or the wires to the switch are bad or the timer is bad.
Posted on Jan 16, 2010
I have a GE GSD 5130 Dishwasher that leaks about 12 oz of water when it is pumping out the wash water and the rinse water. Its fine during the wash and filling cycle. Is it a seal problem?
This is more likely the hose connection at the drain pump or the pump housing is leaking. You will need to remove the toe kick, place unit into a drain cycle and inspect for a leak. Here is a couple links that should help.
http://appliancehelponline.com/dishdraincircpumpvideo.html
http://appliancehelponline.com/dishwasherdrainpump.html
Jul 15, 2010 | GE GSD5130 Dishwasher
I have a GE GSD2230Z00WW dishwasher water will not fill on start no power on the fill valve either. Water will come on quick wash cycle and rinse.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
***If everything checks out ok with the water inlet valve, replace the timer or control board.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Dishwasher won't fill on start
Check the following to address this issue.
Water won't fill, it run through the cycles though
Jun 06, 2009 | GE Nautilus 24" Built-in Dishwasher
GE dishwasher will not fill with water
is the filling valve on the inlet water working unscrew the connecting pipe and see if the water is actually comeing out of the pipe. sometimes when the tap runs at the same time it takes a lot of the water rather than the dishwasher getting it. depending on the pressure. otherwise it might be the ****** pump. try wd 40 on it. it might be jamming.
Mar 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not filling with water. It is not the float. GE PDW 8480 Dishwasher
It could be the fill valve or that the power is not getting to the fill valve. Pull the bottom panel and find where the water line hooks up to the valve. There should be an electrical connector on the valve. First, listen when the dishwasher is at the cycle where it should be calling for water, to see if youhear a click of the valve opening or water running in. If not, and you have a volt meter, pull the electircal connector and check for AC voltage across it when the dishwasher is off - it should be 0, and when the dishwasher normally would fill - it should be something above 0 - it might even be 110v. If the voltage is ok, but the valve is not working, you need to replace the vavle. If the voltage stays 0, then something is wrong in the timer/control circuitry.
Mar 13, 2009 | GE Dishwashers
GE Dishwasher won't fill (Tested valve and switches)
check thermostat it maybe overheat and gives a false signal that water is warm,it is on bottom.
Feb 17, 2009 | Kenmore Elite 45986 Front Load Washer
Water fills up dishwasher after complete maybe a day or two later
Sound like the hot water sonenoid is stuck in the open position. Locate this solenoid and tap it lightly with a small hammer while the hot water is open. If it does not stop it will beneficial to have this part replaced. I hope this will help.
Jan 17, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher problems
The washer may be attempting to run dry. Many times on these washers, a person may open the washer and then go to another load. The washer gets stuck with a dry pump until the timer tells water fill valve to open. Easy test. Start on regular cycle ,slowly advance the timer. it will click until you here the fill start and water will fill until.....
Jul 06, 2008 | GE Dishwashers
Feb 25, 2008 | Dishwashers
Dishwashers Logo
126 people viewed this question
Top Dishwashers Experts
