I need help with my Asus X51R Series. When I boot the laptop, I saw that the hdd and sleep indicator lights up but there is no display on the screen. I waited for several minutes but only the sleep indicator is lighted, still no screen display. What could be the problem. Thanks in advance.
  • 784 Answers
It could be problems with display inverter, Memory modul`s or faulty video chip.
Posted on Mar 16, 2011
  • Jamie McClung Aug 21, 2011
    You need to replace the CMOS battery, check your memory too. Then turn it on, turn it off by holding down the power button for 5 secs, then press and hold the power button to turn it on and display should restore. My X51R had a dead cmos battery, faulty RAM and a corrupted OS- could be related or I could be very unlucky.
    A youtube user summed up disassembly well-
    1.Remove the screen , the screws are on the back. 2. Remove the keypad, there are 3 clips on the top of the keypad. Look at the Esc-key and the F8-key and the Del-key. Push the clips towards the screen and the keypad should be loosen. Remove all the screws you see, remove hard-drive, disc-drive, everything. Carefully open the laptop, unscrew the motherboard lift it up and there is the battery.
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Why won't ASUS G laptop boot up?
Yes; Batteries at the end of their life cycle do act like that.
support.asus.com/
Jun 30, 2014 | ASUS G Series 17.3" Full HD Gaming...
I cannot get my Asus U52F laptop to turn on.
Unplug from AC, remove battery, plug into AC , boot normally.
Dec 06, 2012 | ASUS U52F-BBL9 Laptop
Asus k50 will not start
If the light on the pc, not the power supply is orange this usually means the pc is not comming out of sleep mode. Try the obvious and restart it. If that does not work, attempt starting in safe mode and go to your control panel and turn off all power saving, screen saver, and sleep mode options.
Sep 24, 2012 | ASUS K50 Series K50IJ-G1B NoteBook Intel...
How to Replace Bios? Boot & Reformat Attempts Hang (on every HDD) - I guess BIOS is Corrupted
You can go to the manufacturer web site and go to support then to drivers and downloads there should be a BIOS flash software utility at their site. Click Here to go there. Select your model and make sure it is the correct one. I would also go for the automatic driver update, this will find and seek any drivers for your laptop that are needed, missing, or upgrade them.
If that does not provide the info you need their is also a support number as well as live chat at the link above. I hope this assisted you in some way. John
May 02, 2012 | MSI Computers & Internet
No screen or external monitor display when powered up
when i turn my netbook on the lights turn on but the screen doesnt. I figured out that if i leave it running till the battery goes very low it will turn on.
Jul 07, 2010 | ASUS Eee PC 900 Notebook
Urgent help needed to locate cmos battery laptopasus x51r series
The cmos battery is on the motherboard and unless you are competent at disassembling laptops then I suggest you take it to a repair shop for battery replacement.
Jun 09, 2009 | Acer Aspire 3690-2196 Notebook
Asus x51r powers on then off, no display
Use This way :
• Open the unity central of your pc and search for the small bothers of the clock.
• Pick up and return it in the same place .
• Switch on your pc and see it.
Jan 24, 2009 | Computers & Internet
ASUS notebook gone inactive
It is possible that you switched off the internal video display, enabling the external adapter. If this is the case, you should be able to plug in an external monitor, get your display back, and change monitors back to the internal one via software (display properties).
Jan 25, 2008 | ASUS W7J Notebook
Computers & Internet Logo
339 people viewed this question
David Payne
David Payne
