Question about Acer Computers & Internet
How to remove. i already uninstall and remove from registry but there are confilts with another software(Kaspersky).
  • Ervin Mar 16, 2011
    So you want to remove Kaspersky or another software but Kaspersky doesn`t let you?
  • 746 Answers
Go to documents and settings and then open the folder All Users and then open Application Data and now remove the folder of kaspersky. Your problem will be resolve, for further more information you can contact me back.
Best of Luck
Posted on Mar 16, 2011
How to uninstall iwantsoft total spy
You probably have some registry conflicts or some registry keys were not cleaned up and removed when you uninstalled the software or tried to write over it. The PC thinks its still there or there is a conflict with old registry keys so it can't install. This happens with some software. ( if you are using a MAC disregard ) The following is for PC users only:
First -- if you have not done so already, try using the Add / Remove programs utility in your Windows Control Panel. You can find step by step screenshots and instructions on how to do this at this reference site: http://uninstallmysoftware.com
If that doesn't work, or if the software does not show up at all in your control panel, then follow these steps:
- Step 1 - Select and download any good software uninstaller application that has a free demo or trial version and try that first. Most of the time the free versions are enough to fix the problem - (there are some good ones listed at the link above).
- Step 2 - Install and run the free software uninstaller you selected and follow its instructions carefully - you should see a screen with a listing of all the programs installed on your PC; often more programs than those normally listed in your Add / Remove control panel. Most uninstallers will find software that does not show up in your Add/Remove control panel.
- Step 3 - Find the software you want to uninstall, then select and click "uninstall". All good uninstaller software will do the rest automatically. This next part is very important:
- Step 4 - Sometimes you also have to clean up your computer's PC registry and remove leftover software keys and orphan files from the uninstalled software after running the uninstaller. Some of the more advanced "pro" version uninstaller programs have this feature already built into it and will do the registry cleanup and a backup automatically but some don't. If yours doesn't, then just use RegCure it usually works just as good -- you can find a free link to it on the reference site above. If your uninstaller software does have a registry cleaner built into it - be sure to use it !
Apr 16, 2012 | IwantSoft Total Spy
Upgrading to Windows 7 from Vista with disks supplied by ACER
Try downloading CCleaner, which is free utility that will clean out all your temp files and also scan your registry for issues.
When a program is uninstalled, such as Kaspersky anti-virus, not all registry components are cleared out.
This is particularly the case if the program was a 30 day trial.
The registry retains details of the original installation to prevent consecutive 30 day trials.
CCleaner should clean it out. Run the Registry Issues component until it reports no issues found and then try your install again.
Feb 23, 2010 | Acer Aspire One PC Notebook
I have removed avast 4.0 but it has stuck to my pc i want to install kaspersky but it is asking to remove the avast ,when it not on my pc plese help,,,,,,,,,,,,,,,,,,,,,
just delete the all temp file form system and remove the avast components completely from the add remove progremme option if you have any regisrty cleaner just run that and restart the pc and try to install it.
Sep 07, 2009 | Dell Latitude D600 Notebook
My AVG is conflicting with my installing Kaspersky.
you might not have uninstalled AVG .instead you could have deleted the AVG folder.
AVg components are still there in the registry.if you didnt uninstall it ,install AVG once more and uninstall it manually.
if its not working remove AVG components from registry
here are the instrucions:
To remove the AVG registry entries, open Registry Editor (Start-> Run-> Regedit). In the registry editor, navigate to the entries mentioned below,
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\AVG\Avg8
Right click on these entries and then delete them. If you are not comfortable about deleting registry entries, you can use a free registry cleaner. If you are using a 64 bit machine, then these are the entries to be removed.
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\AVG\Avg8
Once these entries are removed, Kaspersky installation will be completed normally. Alternatively you can also use the AVG cleaner or Kaspersky removal tool for AVG8.
Jul 21, 2009 | Microsoft Windows XP Home Edition
Can't install kaspersky beacause avg8 not uninstalled
u must have not properly uninstalled AVG properly, remove it from registry also. If you cant do it try any uninstaller software to remove avg completely
Dec 19, 2008 | Computers & Internet
I am trying to install Kaspersky and I can't because it is asking to remove the program named AVG8. I tried to with the advice posted on your website but it still is not working.
The first thing you should be aware of is that running two (or more) anti-viruses is often a receipe for disaster. Never install Kaspersky without uninstalling previous installations of anti-virus software, it's not recommended by Kaspersky:http://www.kaspersky.com/faq?chapter=17070...p;qid=169326413.
General removal instructions:
1.Uninstall the anti-virus(es) you have installed via add/remove programsin the controlpanel, then reboot after the uninstall is finished.
2.Next you delete the folder most likely left behind after the uninstall,use explorer to open "Program files" and delete the folder of yourprevious AV, if you get a "In use by other persons or programs" thentry to use a program called Unlocker(free), simply rightclick on the folder and choose "Unlocker" for youroptions to appear. Very useful tool for difficult files/folders btw.You can also use "Search" in Windows to hunt down & delete anyfiles/folders still there after an uninstall. Another thing you coulddo at this stage, is to run a tracks-eraser to remove files not usedand just using HD space, two free tools are: CCleaner (both builds with the Yahoo toolbar and versions without this)
3.Now would be a good time to use a registry cleaner, there are manydifferent vendors, but the one which i find most thorough and safe is RegSupremerun it (use normalmode only, not aggressive), when finished scanningyou rightclick and select "All", then you click "Fix" at the bottom, itwill ask you if you wish to make a backup and you do, just to be safe.
Mostvendors make removal-tools for use after removal via add/removeprograms to remove registry entries/folders, you can contact thesupport of the AV in question for a copy.
Removing Norton (even when it is already uninstalled via add/remove programs)
Nortonremnants is often a source of problems when installing Kaspersky, theseproblems can vary from small and perhaps unnoticed by the user tryingKaspersky for the first time and therefore thinking that it is normalfor Kaspersky to be a little heavy because this is what he/she reads onsome forums, to very severe slowdowns prompting the user to perhapseither contact support or post here at the forum.
Well, the goodnews is that Norton make some very good removal-tools and if you followthe suggestions below, even if they may seem overkill to you, then abetter experience with Kaspersky can almost be guaranteed and withbetter overall system performance to follow in most cases too!
The"bad" news is that you have to uinstall not only Norton AV, alsoSystemWorks, firewall and antispam if you use any of these (these canbe installed again when everything is done, just not Norton AV ofcourse!), however your patience and hardwork will be rewarded with amuch better systemperformance.
If you had 2003-2007 installed you will need the Norton removaltool. You download the tool from here.
You are also encouraged to use a general registry cleaner like RegSupreme,this will find and remove a lot of things so don't be alarmed if thenumber of problems found after the scan is several hundreds, thisnormal, most of them is harmless, but there will also be some which isfrom old installations uninstalled long ago, just let it fixeverything, it will ask if you want to backup and you want this, justin case. Download a fresh copy of Microsoft Windows Script for XP .......or Microsoft Windows Script for W2000 (Vista users should skip this step), Norton sometimes messes with this during an uninstall, so you may as well update this too.
1. Now you uninstall Norton via add/remove programs in the controlpanel, then reboot after the uninstall is finished.
2.Next you delete the folder most likely left behind after the uninstall,use explorer to open "Program files" and delete the folder of yourprevious AV, if you get a "In use by other persons or programs" thentry to use a program called Unlocker(Free), simply rightclick on the folder and choose "Unlocker" for youroptions to appear. Very useful tool for difficult files/folders btw.You may find folders from programs you have deleted long ago, you mightas well delete them while you are in there anyway. You can also use"Search" in Windows to hunt down & delete any files/folders stillthere after an uninstall
3. Now you run the Norton removal-tool.
4.Run RegSupreme (use normalmode only, not aggressive) and fix what itfinds. (rightclick after scan is finished and select "All", then click"Fix" at the bottom or rightclick again & select "Fix")
5. Reinstall Microsoft Windows Script and reboot. You're now finished and can install Kaspersky. (Vista users should skip this step)
ALso seee
http://forum.kaspersky.com/index.php?showtopic=73929&hl=
http://forum.kaspersky.com/index.php?showtopic=72366
Best regards,
Dec 04, 2008 | Acer Aspire 3000 Notebook
How to install kaspersky
You need to download AVG removal tool from avg.com and run it to un-install avg anti virus software completely.
Nov 23, 2008 | Computers & Internet
Problem installing kaspersky
open registry editor and delete the registry values belonging to avg... search using keyword avg etc etc and delete them... usually registry is used to find what all software are present..
Nov 23, 2008 | Acer Aspire 3000 Notebook
Regarding installation of kaspersky
It means there are some applications that were not compatible.
It will list the incompatible softwares when after you select to install.
Uninstall them properly.
You have to remove using proper uninstallation tool.
Like even deleting the traces from the registry.
After this you wont be having any problems.
Good Luck.
Live, Love, Laugh.
Sep 09, 2008 | Microsoft Windows XP Professional With...
I can't remove AVG8.0 from my computer
Hi
Thanks for the solution for the removal of the offending avg8 problem. I was immediately able to install the kaspersky program, after deleting the remains of the avg8 program,you guys are great, will contact you again if need be .
Best regards Ian
May 25, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
