Nat - Computers & Internet
    Brigadier General:
  • 8,909 Answers
"Gnat" is a small insect that bites.
Posted on Mar 16, 2011
Replaced sterring colum now it wont start
S (Nissan Vehicle Immobilizer System-NATS) has the following immobilizer functions:  Since only NVIS (NATS) ignition keys, whose ID nos. have been registered into the ECM and IMMU of NVIS (NATS), allow the engine to run, operation of a stolen vehicle without a NVIS (NATS) registered key is prevented by NVIS (NATS). That is to say, NVIS (NATS) will immobilize the engine if someone tries to start it without the registered key of NVIS (NATS).  All of the originally supplied ignition key IDs have been NVIS (NATS) registered. If requested by the vehicle owner, a maximum of five key IDs can be registered into the NVIS (NATS) components.  The security indicator lamp blinks when the ignition switch is in "OFF" or "ACC" position. Therefore, NVIS (NATS) warns outsiders that the vehicle is equipped with the system.  When NVIS (NATS) detects trouble, the security indicator lamp lights up while ignition key is in the "ON" position.  NVIS (NATS) trouble diagnoses, system initialization and additional registration for other NVIS (NATS) ignition key IDs must be carried out using CONSULT-II hardware and CONSULT-II NVIS (NATS) software. Regarding the procedures for NVIS (NATS) initialization and NVIS (NATS) ignition key ID registration, refer to CONSULT-II OPERATION MANUAL IVIS/NVIS.  When servicing a malfunction of the NVIS (indicated by lighting up of Security Indicator Lamp) or registering another NVIS ignition key ID no., it is necessary to re-register original key identification. Therefore, be sure to receive ALL KEYS from vehicle owner. System Composition NIEL0174 The immobilizer function of the NVIS (NATS) consists of the following:  NVIS (NATS) ignition key  NVIS (NATS) immobilizer control unit (IMMU) located in the ignition key cylinder  ECM  Security indicator lamp.
ANTI-THEFT SYSTEM ! Did you change KEY'S
Feb 07, 2017 | 2001 Nissan Sentra
How do you change from nat type 3 to nat type 2 on this router
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Jun 22, 2010 | Siemens SpeedStream 4200 (13A4200001)...
Change nat type
To reduce the NAT
Mar 31, 2010 | Arris WR850G Router (DHWR850G)
I need to change my nat type from strict to open
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Nov 18, 2009 | Zyxel P660HW-D1 Router
Can't set my ps3 NAT type to type2
if your using a wired router,try putting in the username and password for your PPPOE.mine was nat 3 and went to nat 1 after i done this.check out youtube.let us know
Jan 08, 2009 | Sony Playstation 3 (PS3) Console
Changing the NAT typer from "moderate" to "open"
Follow these steps to use this solution:
  1. Use the no ip nat {inside | outside}command to disable future translations from taking place.
  2. Use the clear ip nat translation command to clear IP NAT translations.
  3. Change the NAT configuration.
  4. Restore the NAT {inside | outside} arguments with the ip nat {inside | outside} configuration command.RICHARDM69
Dec 15, 2008 | Linksys Wireless-G WRT54GS Router...
NAT
Everyone has NAT, whether its strict (which i'm guessing yours is) mederate, or open.
Open NAT can be achieved by buying a new router or connecting your 360 via ethernet to your modem. If you connect it to your modem, restart both the modem and your 360 and you WILL have an open NAT
-Erk
Jun 08, 2008 | Microsoft Xbox 360 Console
My PS3 has no NAT Type!!
there is something known as NAT strict that can happen due to many reasons , NAT or network address translator helps in converting the WAN ip address to LAN side IP address or public to private ipaddress . In a case of NAT strict or no NAT type ur PS3 or the router to which you have connected the PS3 is not able to convert the IP address...
Solution: try logging on to the router manager or PS3 settings and enable the NAT ( it would be in a disabled state or DMZ ( de militarized zone ) state )....
If the nat is already enabled Then try to manually configure NAT by opening the port numbers on the router manager or PS3. Port numbers can of UP or TCP protocol depending upon the games ur tyring to play....
If u donno how u do it then contact sony or the people who gave u the router or ur ISP
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
NAT Traversal
NAT traversal refers to the common problem in TCP/IP networking of establishing connections between hosts in private TCP/IP networks which use NAT devices Client-based IPsec VPN connections often do not work when passing through a NAT device as the IKE and IPsec protocols were not designed to work through NAT. NAT Traversal is an add-on to the IKE and IPsec protocols that allows them to work when being NATed. NAT traversal is only used if both endpoints support it. D-Link products that currently support NAT traversal include the DFL-200, DFL-700 and DFL-1100. Note: The DFL-80 and DFL-300 do not support NAT traversal.
Feb 16, 2006 | D-Link Express EtherNetwork DI-804HV...
Computers & Internet Logo
336 people viewed this question
David Payne
David Payne
