Question about HP LaserJet 4 plus Printer
Printer prints old jobs as soon as i start my macnine every morning.. its shared on my machine to others as well.
  • HP Expert
  • 217 Answers
you can unshare it :)
or you can describe a posible time for printing for other users by using driver options menu
for example - all other users can print only between 12:00 AM - 13:00 AM
Posted on Mar 16, 2011
Spooler hangs/freezes when sending any print job to network share printer. I have tried every fix I could find online. I finally ran a sfc scan and fixed a corrupted windows file, the printer will p
I think you're on the right track with the firmware and driver updates, but be careful about your driver and version selection. For instance, I have an old usb Minolta Laser and XP wants to install the driver for the 1200W. Problem is, my unit is a 1250W. It works eventually, but my spooler hangs for a solid three minutes and network jobs always fail... Good luck sir.
May 21, 2014 | HP Color LaserJet Pro 400 M451nw
Hi i have Xerox 7760DN with both ps anc pcl enabled - there's a 68 page document getting prited everytime the printer is turned with bunch of gibbersih from startup. DO you know the resolution for
Sounds like a print job was sent to that printer using the wrong print driver. Unplug the printer from the network and see if it only prints the startup page. If so, then you need everyone to cancel the print jobs they sent to this printer. Then hook the network cable back to the printer and see if a print job can be sent to it (one that has worked in the past). I suspect someone has an old printer driver that is using this machines IP address to print to and it is confusing the Image Processor Board...
Apr 04, 2013 | Xerox Phaser 7760DN Laser Printer
I have an ip3500 canon printer that is about 3 years old. I was printing an article this morning and when I went to print another the printer would not respond. The on light is not on. I have unplugged...
Check the printer job queue by clicking on the printer icon in your system tray. Most probably your previous document is still pending or something.
Right click or in the main menu, select delete all print jobs and then try printing... this should solve the problem.
You could also clear all pending jobs through start... control panel... your printer...
Another thing to check for is if your default printer is still the same and if it is showing as online.
Please mark this solved if it is.
Jul 31, 2010 | Canon Office Equipment & Supplies
How to know who is sending a job to the printer using the network?
The best way I can think of is to print to the printer using one PC printing locally to the IP directly and then set up the other computers to print to the shared printer on your machine. Then any jobs entering the queue will have the machine name or username of the PC submitting the job and you can set policies, usage, and other restrictions with GPedit. I think at that point you can even track the activity in the Windows event viewer.
May 12, 2010 | Toshiba E-Studio167 Copier
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Printer Not Woking In Network
1. check that not any firewall or antivirus software blocking your printer.
2. try to look in paper settings what format you sending to the printer. is it letter format or A4 or what ? it should be A4.
have you tried to connect the printer with USB? or have you connected the printer with a network cable.?
Jul 03, 2009 | HP LaserJet 1022 Printer
My shared printer will only print a test page and nothing else!
Hi phall124
Have you made the new connected printer on 2 other PC's the default printer. Try selecting the printer in word by not just clicking on printer icon but using the following:
1.File
2.Print
3.Select printer from drop down box
4.Print
Regards
Go-Tech
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
LAN PRINTING NOT WORKET ON RICOH 1600LE
use an updated driver version for this machine on ricoh-support.com, another solution is using pcl5 driver as this one does spooling at computer and not machine...
Dec 06, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
KM3035
I assume the print driver is on the server and shared. I would start there. I would think someone changed the default setting on that driver. Go to printing preferences, job tab, and see how it is set.
Or re-install the print driver and start over.
Of course, on any problem, Kyocera will always ask you if you have the latest software installed on the machine.
Aug 07, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
HP LaserJet 4 plus Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
