Question about HTC Touch P3450 Smartphone
Screen suddenly turn white and done all that i could like hard reset but when i switch it on again, it was normal only for a few seconds before turning to white screen again...
    Sergeant:
    Novelist:
  • 164 Answers
If you you are experiencing white screen and nothing changes even after doing a hard reset you may want to call or contact HTC support. Be sure that it is still cover by their one year warranty. Coz having a white screen might caused of a lot of things like infected by virus, water incident, mobile phones has a physical damage. Check as well the lcd of the phone. try to get in touch with them with the link below.
http://www.htc.com/sea/CA_Hotline.aspx?region=NorthAmerica
Posted on Mar 16, 2011
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Hello!My Nokia x3 is a year old and since 2 weeks or so, suddenly the screen would get white and then black like shutting down. So far it would last a few seconds and get back to normal, without me...
there are some steps you should check
1.take out your battery and check whether it is bulged or not..if yes replace your battery
2.switch off it for 24 hour and try switching on again..if the s40 interface has come reset it immediately to make sure no malicious programs are in there.
3.if you could do the second step..please update your phone
Jul 27, 2011 | Nokia X3 Cell Phone
Hello, I have the Asko W6761 and all of a sudden it doesn't run the cycle anymore. It starts normally, i.e. pumps water into it, but then it doesn't start to wash..any idea what this could be? After a few...
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Toggle the power switch
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
W6761 seems to be weak at high ambient temperature.
Tsunett
Oct 26, 2010 | Asko W6761 Front Load Washer
Screen has turned white no display
my screen is not appearing it started last four moths after some few minutes the time comes and when any of the key pad is pushed sudden it will vanish and the screen turns white.
Jun 08, 2009 | Sony Ericsson K750
White screen
YOUR BOOT IC NEEDS TO BE REPLACED ...SO PLS CONTACT NEARSET NOKIA SERVICE CENTER...
May 17, 2009 | Nokia N70 Cellular Phone
When i try to turn on my macbook nothing shows up on the screen and the white light on the bottom right turns on and stays on
Plug the power adapter in. Then hold down the startup button for 15 seconds. The light should go off and then after a few seconds. restart normally. The macbooks have a safety device that will lock up the drive if it detects sudden movements to protect the drive...
Let me know if you're back up and running. KEN
Apr 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Archos 605 WiFi stuck
Hey
I suffered the same problem as you, fortunately I fixed it after a lot of messing around.
First what you want to do is switch off the system completely. Once the power light is off, switch the system back on, once the LCD screen turns on, immediately press and hold down the YV/LCD screen for about 5 seconds, a white screen should appear.
You will have three options, click the second option, (i think it is repair) and connect the archos to the PC. This will allow you to transfer all your files to PC because you can access the harddrive.
Once you have taken all the files you want, turn the system off again. Then again, turn the system on, hold down the TV/LCD button for 5 seconds until the white screen appears. Choose the format option. This will take your archos back to factory settings. It took me a few goes to get it back to normal but once its done, you will be glad you put the effort in.
Now all there is to do is to take your files back across via cable and you should be done!
I hope that helped!
Aug 03, 2008 | Archos 605 WiFi Digital Media Player
Nokia N70 Screen gets white blank
check your battery! i think you are using duplicate battery! put original battery to your mobile! again the problem came mean install new software and format your mobile
Jun 30, 2008 | Nokia N70 Cellular Phone
My c250 turns on, but not in the way I would like it.
Try a hard RESET by holding the POWER and the MENU for about 15 to 20 seconds. That may reset the player back to the factory settings.
Jan 07, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
HTC Touch P3450 Smartphone Logo
142 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
