Question about Car Audio & Video
Philips 326559176 No. 09146055 TYPE CAR 2004 (E) UU1
Motherboard display problem
watch this
http://www.google.com.pk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CBsQtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D9Y2R2wlGq9M&ei=Kh1sUNrnH4PJrAfGjoH4DA&usg=AFQjCNFR3qS4Z9A7XCohaALnrh8MKyTycg&sig2=uu1-8U0LzSJnAR35FoL_PQ
Oct 03, 2012 | Intel 845GE Motherboard
NEED RADIO CODE FOR Philips 326559176 No. 09146055 TYPE CAR 2004 (E) UU1
Need radio code for
PHILIPS 326559176
No.:09 119 984
TYPE: CCR2006 (E)
UU7
WA080204
Mar 16, 2011 | Car Audio & Video
Hi I need a code for my Philips R770 Rover
If it is the standard stereo unit fitted to the car from the factory then you need to call the car manufacturer to get the code. If it is not then you need to call the manufacturer of the stereo to get the code.
Nov 11, 2010 | Philips Car Audio & Video
INSTRUCTION MANUAL FOR PHILIPS CAR 400 2F3
Philips NO. : 09136106
GM040013070337
icon_minipost.gif icon_quote.gif Type: Car 400
2F3
other number:
9022 213 99759 02
003 0119 30703 37
WA020119
Oct 04, 2010 | Car Audio & Video
How do i remove a radio from a 2005 toyota Sequoia? More specificaly, how do you remove the dash trim around the face?
There is an AC vent on either side of the radio. Push the vent in on the top, so that the vents are aimed upwards.
You will not be able to see two philips screws just above the vents. Remove them.
Some knob type AC units have a screw behind the center AC knob as well, that you can pull straight off.
2004 I *believe* should have the push button ac and no bolt on the bottom.
Once the screws are out, the bezel will pull straight off, unplug the wires then set aside.
The radio has 4 10mm bolts or philips screws holding it in (some bolts had a philips cut on them as well).
Remove them and pull the radio straight out, unhooking the cables/antennas
Oct 28, 2009 | 2004 Toyota Sequoia
Where is the fuel filter on my 2004 Jaguar x type
Passenger side, in front of rear tire ares close to front of fuel tank under car.
Oct 25, 2009 | 2004 Jaguar X-Type
Security code
HYUNDAI RADIOS DO NOT HAVE SECURITY CODES.UNLESS ITS AFTER MARKET.CONTACT YOUR LOCALL RADIO SHOP
Jul 05, 2009 | 2004 Hyundai Elantra
Car Audio & Video Logo
247 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
