Router I recently switch from DSL internet service to cable internet service and I had an wi-fi with no problems but now that I want to reinstall my router to the motorola Cable modem it does not work why can you help?
  • Anonymous Sep 09, 2008
    i cant find the reset button on the router??? i cant find anything at the back except the usb, rf, and where you put the ethernet wire..
  • 304 Answers
Hey, Here I am. Press the reset button on the back of the router. The button is in a small hole in the back of the router. Unplug your modem and your router. Plug your modem back in and let it initialize. Plug in your router and let it initialize. Now log in to your router as per the directions and set up the router with whatever security measures you want to use. If you need further assistance feel free to ask. This should fix your problem though.
George
Posted on Aug 05, 2008
  • 298 Answers
What is the brand and model no. of your router?
Posted on Aug 04, 2008
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Why my phone not connect internet service?
You have to set it up. Your phone will only connect to a Wi-Fi service not your home DSL or Cable direct. If have a have modem or Router which accept Wi-Fi then you can use your phone for your own local ISP. Its only a setup problem, knowing the same information as you setup your computer at home.
May 10, 2014 | LG GX500 Cell Phone
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
IsEA6500 smart wi fi router agood choice for DSL
Really any quality WIFI router would work with any internet service. The router should not have any affect on the dsl modem.
Jan 23, 2014 | Cisco Linksys EA6500 Smart Wi-Fi Dual-Band...
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Wii Error Code 91010.
Error Code: 91010
Our experience shows that error messages within this range are typically caused by temporary network issues with the Nintendo Wi-Fi Connection. If there is a problem with the network, our technicians will work to get the service back up as soon as possible. Please retry your connection later.
If you are connecting to the Nintendo Wi-Fi Connection for the first time, or the problem has not resolved itself after a few hours, please review the following:
  1. Our servers may be trying to handle an unusually high amount of traffic (especially if you are trying to play online with a recently-released or popular game, or if there is a new Wii system update). Please wait a few hours and try the connection again later.
  2. How are you connecting online? The Nintendo Wi-Fi Connection is only compatible with Cable, DSL, and Fiber-optic internet connections. If you are connecting via Satellite, EV-DO (cellular), Dial-up, or other types of connections, then you should try to use an alternate type of connection. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  3. The error may be caused by a basic setting on the router that needs to be adjusted (such as the channel). Please review our general router troubleshooting.
Sep 12, 2008 | Video Game Consoles & Games
NEW BELKIN WI FI CABLE ROUTER NOT WORKING AFTER 4 DAYS OF USAGE
I would try a hard reset of the router to reinstall the original settings. Then reconfigure and test again. If ther is no change then as you probably suspect the router has failed. Let us know if you have any other questions and please don't forget to rate this posting.
Feb 06, 2007 | Belkin Wireless Cable/DSL Gateway Router
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
