Question about HP 2133 Notebook
Hp mini 2133 problem. blue light on. black sreen
  • 2,296 Answers
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Posted on Mar 16, 2011
  • 784 Answers
How it looks. Is ther any text?
What should i do to boot my hp mini 2133
Does it seem like it booted all the way except the screen is black? Do you hear fans running, the hard drive spinning?
What is a hard reset? Exactly what did you do?
Apr 25, 2012 | HP 2133-1 Mini-Note PC
Hai sir . hp mini 2133 power on , but no display power on power swich blue light on only fan working no problum plese answer me sir
i have exactly the same situation ! , just previously it would hang up , and recently i had done the restore thing ..
Jun 04, 2011 | HP Computers & Internet
My hp 2133 just stopped working !!! now when i am trying to switch it on- the monitor is all black .......nothing is coming on the screen . How can I solve the problem?
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 24, 2011 | HP MINI 2133 Notebook
Hp mini 2133 problem. blue light on. black screen. fan is running. is it the memory module or the motherboard that is causing the problem?
in this wise have u tried trying it with another memory module?
if not pls do try it so as to enable you ascertain what the problem is and after you might have done these and the problem still persist i will advice you to contact a laptop technician
Jan 02, 2011 | HP 2133 Notebook
My HP Mini 2133 do not turn on.
Remove Power Supply. Remove Battery and let Stand for 20 minutes unplugged and BaTTERY OUT.
Return Battery, Plug in Power Supply and push START BUTTON.
It should Work again.
If that does not work ,and its no longer under Guarantee: Take out the battery and close top; run over with SUV TIRE and send back to HP :). These Mini s are mostly Junk and poorly designed. The only ones that pass muster are the IBM LEVONOS they ROCK!
Aug 20, 2009 | HP 2133 Notebook PC
HP 2133: does not turn on, sreen blank
i solve this prome!!!!!!!!!!!! do you still have this problem?????
Jul 04, 2009 | HP 2133 Notebook PC
HP 2133 Notebook Logo
485 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
