Question about SanDisk Sansa Fuze MP3 Player
My sansa fuse 4GB seems to have lost most of its internal memory.Although I've deleted everything from the unit , I'm left with only 35 MB free of 3.65 GB.How can I retrieve all the internal memory?
  • 482 Answers
You should format the memory of your player but if you have important files on the device make back up of them before. You have two possibilities to do the formatting:
1. On the player use the device Format command under Settings and Format option.
2. Using your computer, and windows explorer select the drive of sansa and right click on and choose format. Type of it should be FAT.
Then you already should find all the internal memory in the device.
gylacz
Posted on Mar 16, 2011
How do I delete 30mbs from my sansa clip the message is: not enough space for music DB. Please free 30mbs
The player needs free memory to build its database for playlists to playback.
To free memory on your player:
1. Connect to a computer
2. Save a backup of (preferred all) songs to a location on the computer
3. Delete some files off the player to free at least 30 MB memory in the Sansa Clip
Use the manual for how to connect and delete music files.
Clip manual:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Need more help ? Just add a comment in this thread.
May 21, 2010 | SanDisk Sansa Clip MP3 Player
I inserted a 2gb micro sd card into my 4gb sansa fuze for more memory and it's still saying I don't have enough space on it when I go to add a song off of limewire
Inserting a microSD card into the Sansa does nto magically expand its internal memory. The card is a separate chunk of memory. You can move some songs from the internal memory to the card to free up some internal memory. Or you can add the new song to the card.
May 15, 2010 | SanDisk Sansa Fuze MP3 Player
Says" not enoughh space for music db please free 8 mb" wont let me put music on or delete
Try removing the microSD card then delete something from the e250's internal memory to free up 8MB.
Feb 07, 2010 | SanDisk Sansa e250 MP3 Player
Sansa fuze 4GB memory is full
I had this same issue today. I actually followed someone else's post and used my computer to reformat it (right click on it in Windows Explorer, and choose Format). This worked. I just loaded it back up and am good to go. Good luck!
Jan 10, 2010 | SanDisk Sansa Fuze MP3 Player
"Not enough memory- FREE 6MB?" Songs DELETED!!!
connect the player to PC and format it...that must solve the "free x mb for music DB" problem
Sep 02, 2009 | SanDisk Sansa e250 MP3 Player
Can an 8GB microSDHC card be used in my Sansa Fuze 4GB mp3 player
Actually, it sounds as if the card is working. The more you have on the card, the more free internal memory you'll need so it can build its media database. Remove the card, then delete some files from the internal memory to free up space. Then reinsert the card.
Jul 06, 2009 | SanDisk Sansa MP3 Player
Internal memory almost few with just 153 MB of tunes!
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 02, 2008 | SanDisk Sansa Clip MP3 Player
Error Message
Remove the microSD card and then delete one or more files from the Sansa's internal memory to free up an additional 90MB.
Jul 02, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
E260 shows 0 MB memory and 0 MB free space after recovery
Look, I think the best thing to do is to return the product. Normally, they gave you a new one. My old one broke with a blank screen. So the bestbuy guy talked to his manager and gave me a new one.
Apr 24, 2008 | SanDisk Sansa e260 MP3 Player
Sansa 4gb mp3 player
perform recovery mode on the player and create a file named sansa.fmt and put that file in the 16 MB format that should reformat the whole player after you have put that file in the drive and unplugged the player from the computer. After that has been done try to update the firmware of the player.
by this u can delete fully and clear
Dec 27, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Fuze MP3 Player Logo
153 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
