Question about Dell Computers & Internet
My computer can't connect to the internet, by means of ethernet.
  • 118 Answers
Try installing the drivers, or enabling it on network connections.
Posted on Mar 16, 2011
Testimonial: "Thanks Mate!"
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
I just moved in to my college dorm yesterday and you have to use an ethernet cord for internet in my room. So I bought one, and when I plug it into the wall and into my computer, the ethernet port has a...
The lights means the port is active and working. Does the lan connection show as connected on the computer, what IP are you getting if any? Does the college use a proxy?
Aug 30, 2011 | Toshiba Ethernet Cable (cmcable)
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Linksys Wireless-G WRT54G Router
Ethernet/lan missing so i can not connect to the internet
Download and install the driver from the manufacturers website. Use an external hard drive or flash drive to download from internet (working computer) and install from there.
Oct 03, 2009 | Foxconn 915P7AC-8KS Motherboard
Last week I put a 4-hub on my desktop and laptop. one wire from wall to main hub, one ethernet cable from hub to laptop, one ethernet cable from hub to rear ethernet port on desktop. The internet on the...
check if we are getting good ip address 192.xxxxxxxxxxxxxxxxxx
not the 169.xxxxxxxxxxxxxx
relese renew if 169.xxxxxxxx is the case
if no reply.. try using another cable and check the connections
Sep 20, 2009 | Dell Latitude D600 Notebook
Please clarify what you mean by ''Connect with an ethernet cable''
Ethernet cable means CAT5 or UTP for others or LAN cable. The connection should be LAN port of your computer to LAN1 of your router.
And you can connect also the internet cable usually ethernet cable from your internet provider directly to (ethernet cable)WAN port of your router to get signal from your internet provider.
Also if you get this message, this could also means you still don't set up or configure the router's settings to communicate when your LAN and router. They must see each other to access the router's utility webpage.
Regards
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
Brand new linksys wireless, Host (Hard wired)has intermittent connectivity. Indicates it is conneted and is working properly.Cannot browse Web. The wireless part works great!
try to plug the Ethernet cord for the Host computer on another Ethernet port on the Linksys router.
have you tried replacing the Ethernet cable that's connecting the Host computer to the linksys router?
check if Host computer can get a response from a website by going to Start>Run, then type CMD on the Run box and click OK. On the black screen, type PING www.yahoo.com then press Enter.. if you get the word reply 4 times, it means the computer is connected to the Internet.
If there's no response from the PING test, it means there's totally no connection.
It's also possible the problem is with the Local Area Network adapter or Ethernet adapter. Try disabling the Ethernet adapter and re-enable it by going to Start>Control Panel>Network Connections, you should see the Local Area Connection, right click on it then select Disable then Enable it again. then observe if you're still experiencing intermittent connection on the Host computer.
and if you have security software, try disabling it temporarily and check the connection again.
and let's make sure the cable or dsl modem is connected to the Internet port on the back of the Linksys router.
May 10, 2009 | Linksys WRT160N Wireless Router
Ethernet
dear ashprabha,
you are saying that your motherboard doesn't have a on board Ethernet slot. now, if u want to connect to internet means
then you have to purchase and fix a PCI Ethernet card. so that you can connect to internet.
Sep 26, 2008 | Intel Motherboard
Wireless router to modem problems
Since it says network cable unplugged on the computer when wired to the router, you need to check these first:
â Make sure that the Ethernet cable is connected from the modem to the router’s Internet (WAN) port and the computer to the numbered port of the router. The computer should used to be connecting to the Ethernet port of the modem, if not; you should contact your ISP first.
â Make sure that the Ethernet adapter/LAN card on your computer is working properly. You can check that on the device manager of your computer.
â If those are all working fine that would mean the router is not yet configured for Internet access or we can say that the settings for the provider are not synchronized with the router.
To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
Sep 23, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
77 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
