Question about NAD T765
I have one of the first 1500 T765's produced (the ones without an iPod port). I wanted to upgrade it with the AM 100 and VM 100 boards in order to have HD audio support via HDMI. I have been told by my dealer that these early models will not process HD audio formats, even with the upgrade boards. Is this correct? If so, I frankly feel cheated, since I was not informed of this limitation when I bought the unit. Is there somebody at NAD with whom I can take up the issue?
2 Suggested Answers
  • 643 Answers
SOURCE: the display of my nad
The lamps may be burned out. Try replacing lamps.
Posted on May 09, 2011
I want to upgrade my RAm from 256 to 1 gb DDR 1 , Dose A7N266-VM Rev -1.05 mother board supports it ?
amd processor? yes you can upgrade it and do not install the 256mb ram together with the 1 gb memory that you want to upgrade, better use the 1GB alone,
Aug 04, 2011 | ASUS A7N266-VM Motherboard
Hello, my main board is asus p4p800-vm running xp home with sp3 upgrade with ide hdd's and is running well. i bought 2 new sata hdd's because the board has 2 sata ports, i set the bios to auto to see the...
Windows will not see them because you need to download the SATA drivers for the motherboard from the Asus site.
Download and install to a floppy or USB (advise the latter)
Install windows,and you will get a "press f6 if you want to install a raid device ..."
Press F6 and hopefully, windows will find the drivers, highlight the ones it wants.. the rest should be simple
Jan 06, 2011 | ASUS P4P800-VM MB, 865G/ 800FSB/ SATA/...
No power to usb or monitor ports
Yes, the motherboard has failed - its chipset to be precise. Time for a new one.
Jul 18, 2010 | ASUS M2A-VM (0610839149438) Motherboard
How can I sharpen blades on a Norelco T765
You can not sharpen these blades. To sharpen them, you would have to be able to remove each blade frm the plastic cartridge tht holds them. This type blades are manufactured in such a way that there is no way to take out each of the two individual blades without breaking the part that holds them.
Feb 13, 2010 | Norelco T765 Beard Trimmer
Is it compatible a intel dual core processor to a
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Jul 15, 2009 | ASUS P5PE-VM Motherboard
CPU Upgrade
Hi there.
Here is a list of processors that board will support >>>>>
Good luck and thanks for choosing FixYa!!
May 27, 2009 | ASUSTeK M2A-VM HDMI Desktop Board - Athlon...
Looking to upgrade hard drive
Pretty much just how big of one does he want.
Jan 07, 2009 | ASUS NVIDIA nForce Chipset A7N266-VM...
Upgrade P5RD1-VM motherboard to the gaming PC
Your pc is not for gaming right now because you are using Intel Pentuim 4 Mother board and CPU. Amd Athlon is best for gaming. I have a AMD Athlon 4200+ X2 with 4gb Ram and Nvidia 6800 256mb OC. to upgrade your computer to a gaming pc. you will need to switch your motherboard and cpu for best performance on games. in order to do that, you might need a different case for your new motherboard. because the one you have might not be right for the AMD Athlon motherboard unless you have a custom made computer. other than that everything is set for you. if you have less than 1gb ram you might want to add more. because the games they are coming with right now is 1gb minimum or required.
i hope that answers your question.
Thank You
Dec 08, 2007 | ASUS P5RD1-VM Motherboard
IDE ports in asus m2npv-vm & m2n-mx motherboards
hi, i have a couple of those boards. they have 2 ide ports on them and 4 serial ports. if youu do get the m2npv-vm, one thing that is weird about it, one faces up from the board and the other lays flat off the edge. also the ports are right next to each other and the polarity (which side you put the ribbon cable stripe on) is opposite each other. so if you don't use a keyed ribbon cable you might hook them up wrong.
Aug 22, 2007 | ASUS M2NPV-VM Motherboard
NAD T765 Logo
Top NAD Audio Players & Recorders Experts
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
