It sounds like the bottom bearing is faulty a audible squeaky noise is very evident I am concerned abount overheating and possible fire
    Sergeant:
    Champion:
  • 250 Answers
Sometimes on the fan motor the bearings have to be lubricated. You have to remove the cover on the air conditioner with the unit unplugged and squirt a drop of 3 and 1 oil where the shaft and motor meet.
Posted on Mar 16, 2011
Why is there a squeaky noise coming from the right front wheel whenever I drive for 20 to 30 minutes?
Could be multiple things. Wheel bearing, lug nuts not all the way tight. Or you could need brake pads
Sep 13, 2015 | 2005 Saab 9-5 Sedan
Is it possible to adjust the timing on a 1.4L petrol Holden Barina 2001 engine?
If the engine ran with out coolant and damaged the head then there is a very real probability that the pistons have picked up on the cylinder walls which will cause the noise . Do a compression test to see the condition of the rings (lost tension) and the bores
Dec 21, 2014 | Holden Cars & Trucks
How do I fix a squeaky belt on a minivan?
Post question is automotive section?
Is belt squealing? or is there a squeaky noise?
Squealing would denote belt slippage... belt might be loose, apply more belt tension at idler pulley (if possible). Consider trying a spray-on 'anti-slip" compound.
Squeaky noise could mean a bad pulley bearing.
Oct 13, 2014 | Dryers
Squeaky sound coming from car. got breaks checked and still squeaking. someone told me it is most likely the wheel bearing
It is possible that it is the wheel bearing especially if it is metal contact you are hearing. To be sure swap your wheels from back to the front and see if the noise transfers location. If it did it could be the wheels.
Jul 21, 2011 | Saturn Ion Cars & Trucks
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
My dryer makes a squeaky sound during adrying
the front guides around the drum or the bearing at the back may be failing partially or bearings in the motor may have started to noise,there is also the chance that the belt idle pulleys have started to wear,more than lightly it is the belt idle pulleys that have dried up or the bushings have started to wear
Jun 30, 2010 | Kenmore 94702 Front Load Stacked Washer /...
My check engine light is on. There is a squeaky cricket noise when the car is in motion; it is not a loose belt. I don't want to take it in and be overwhelmed with major engine problems. Any ideas what it...
for the check engine light:
-you can go to auto zone and have them hook it up to the computer for free!!!!!
for the squeaky cricket noise:
-could possibly be a wheel bearing starting to go bad, or possibly a wear sensor on the brakes....
that is only if it makes the noise when the vehicle is in motion.... if the sound is there while it is sitting still, then you could have a pulley bearing going bad... hope this helps.... please rate this...
Apr 12, 2010 | 2002 Mercury Mountaineer
Air conditioning compressor making squeaky sound
can someone tell me if a squeaky noise when I turn on my ac in my yukon, means the air compressor is going out? Please help!
Aug 15, 2009 | 2003 Chevrolet Tahoe
1999 Subaru Legacy GT - Front end humming
@ 175K miles the Idea of Transaxel Output Carrier Bearings Should Be Considered. BUT What you Describe My Experience tells Me Wheel Bearing, It Being a All Wheel Drive Vehicle Makes it Very Difficult to Call This with Confidence as I Am unable to Roadtest it. Hope this Can Help To Lead you in the Right Direction
Feb 12, 2009 | 1999 Subaru Legacy
Squeaky elec. dryer
This could be attributal to a rear drum roller lacking proper lubrication, or having been overheated. Also, a dry idler pulley bearing could cause this chirping. Don't allow this problem to continue without investigating the cause.
May 27, 2008 | Maytag SDE2606 Electric Dryer
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
