Question about Dell Latitude D610 Notebook
Wireless not working on Dell D610, installed drivers, enabled in bios able to use FN F2 key show icon but no lites above keyboard
  • 118 Answers
It might be diasbled. try windows key + "x", if this doesn't work when you turn it on there, try going to network connections and enable the wireless. Go to control panel, select network and sharing, change adapter settings, you'd have something like wireless network connection, right click and click enable if its disabled.
Posted on Mar 16, 2011
Where is the wireless button
The Latitude D610 does not have a wireless button.
Jun 14, 2014 | Dell Latitude D610 Notebook
Wifi problems with Dell Inspiron E1705
LOL, sounds like you didn't hit the correct key or keystrokes.
First of all look in front and on the sides for the Wireless Switch and make sure it is turned on. Then once it is on you can toggle the wireless on or off by Keystrokes. Press and Hold the FN key located at the lower left portion of the keyboard, then hit the corresponding F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the icon of the wireless signal )))) or it will have the icon of a tower with the wireless signal )))). Normally when the correct keystrokes is hit the screen will display Wireless On or Wireless Off.
May 05, 2012 | Dell Inspiron E1705 Notebook
How do you turn on wifi for dell latitude d610
There is not wireless switch on this model. To turn on your wireless you will need to hold down FN + F2. If this does not turn on your wireless its most probably disabled in the Bios. To enable it, press the F2 key at the Dell Logo on startup, move down to wireless, press enter and move to wireless control, make sure its set to Fn+F2/App, then move down to wireless devices and make sure it set to on. Press Esc, and save changes and exit.
Sep 08, 2011 | Dell Latitude D610 Notebook
Where is the "wireless" on/off
First make sure that wireless card is present in your system and it is enabled( Check the BIOS settings).
If so, you can enable/ disable wireless by pressing Fn+F2 keys, and the wi-fi light on the right hand side will turn on.
Let me know if any clarification is needed. Hope this helps!
CreativeTECH
Nov 19, 2010 | Dell Latitude D610 Notebook
I am unable to activate wireless card. I have to press Fn f2 key but the f2 key on my keboard doesn't work. I tried connecting a wireless keyboard (it doesn't have Fn key), then pressed Fn on laptop, F2...
It could be a drivers problem... Unistall the drivers from the device manager and install a fresh one from the dell website.. Try pressing the FN+F2.. Still no go.. Try to check whether the keyboard is working.. Still no go - resaet the Wireless card... Still no go.. Replace the wireless card..
Sep 06, 2010 | Dell Inspiron 6000 Notebook
I have a dell latitude D610 and am having problems connecting to the internet via my netgear router. I have had this problem in the past and the solution was a series of keys (fn,f2) but am not sure of the...
Maybe this is what you had done? I found this post -
"Quote" Most Dell laptops have three places you can turn the wireless on and off
The first is in the cmos setup - Hit F2 at startup and go through the pages until you find the one that allows for wireless control and make sure the wireless is enabled.
The second is through a keyboard "hot key" combination - usually FN+F2 - you'll need to look at your keyboard to verify this. "End Quote"
I found it on this site - http://forum1.netgear.com/showthread.php?t=3056
Jan 30, 2010 | Dell Latitude D610 Notebook
I would like a manual for the latitude D610 keyboard to know how to use the symbol that are highlighted in bleu
In the lower left hand corner of your Dell Keyboard -- you will see a Blue Key labeled -- "Fn". This key allows you the use of ALL of the other blue labeled keys on your keyboard. You must press the FN key and the other "blue" key at the same time for them to work.
The keys on the right side of the keyboard with the blue numbers on them are controlled by the Numlock key and Fn key. The light at the top of the keyboard near the power button, with the number "9" inside a picture of a lock, will be lit if the Numlock is enabled.
You may need to press the Fn key to type numbers even if the Numlock is turned on. There is a setting in the BIOS called Enable Keypad and if you set it to By Numlock you will not have to hold down this key to type a number.
If you are still having trouble with these keys, please see the general keyboard troubleshooting guide
http://ftp1.us.dell.com/diags/R65848.htm#Key not responding or typing wrong character
Jan 13, 2010 | Dell Latitude D610 Laptop Computer -...
Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
Apr 03, 2009 | Dell Inspiron 6000 Notebook
Bluethooth not working
Enable the Wireless switch in BIOS.
to access BIOS...press F2 when you see the Dell logo
Mar 12, 2009 | Dell Inspiron 1525 Notebook
Computer bios
Most systems today you can enter the BIOS with pressing F2 at boot. Some use F1, F10 or Del to enter setup (It should be on the screen at boot which key to enter setup) Once in BIOS navigate to the wireless device and see if it is Enabled
You can also look at the Function Keys, as most portables have a Fn + functin key combination to enable wireless (look for a radio tower Icon on a Fn Key, With Dell it is Fn+F2 not sure on HPs)
Jan 26, 2009 | HP Compaq nc6000 Notebook
Dell Latitude D610 Notebook Logo
528 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
