Question about Admiral Washing Machines
Purchased new Admiral washer model ATW4475TQ0. Installed washer, water hoses connected correctly. Problem with temperature setting. Set temperature control to cold water wash and get hot water. Set to hot water wash and get warm or at time cold water. Factory technician came out is comments where "part failure: connectors to fill valve (water temperature sensor) were reversed. But now when on rinse cycle I always get hot water rinse no matter what the temperature setting.
  • 26 Answers
SOURCE: Hot water will not fill into the tank when starting cycle.
You probaby have an inop hot water fill valve.
Posted on Dec 19, 2008
SOURCE: No cold water rinse
called a repair person.
Posted on Mar 24, 2009
farfield
  • 462 Answers
SOURCE: water is always hot
Turn off the water from your hot water valve at the wall. See if you get any hit water then. If you do it must be comming in from the cold water side. If you dont get any water to flow the water valve or selector switch is at fault.
Please rate me as high as you can and thsnks for using fixya.
Posted on May 10, 2009
canbruce75
  • 1776 Answers
SOURCE: maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Posted on Aug 10, 2009
miket756
  • 2702 Answers
SOURCE: My admiral washer ATW4475TQ0 makes a thumping
there are stabilizers on the drum if they have fell off or broken away the drum will swing wildly around on spin this will cause the drum to "hit" the inside of the washer,,,check the drum stabilizers are in good order
Posted on Aug 08, 2010
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Just purchased a new Admiral Clothes washer. When
Could you check and see if both the hot and cold hoses hooked to the back of the machine are actually putting out hot and cold water? If they are, it may be time to return the washer to where you bought it and get another. Be blessed.
Sep 25, 2013 | Admiral AW22 Top Load Washer
When the washer is ready to wash,the water keeps coming in to the washer,won't shut off
Open the control panel. Remove the plastic hose from the water level switch.
Blow through the hose to remove any blockage from the air bell at the tub. Reattach the hose and set the machine for a SPIN cycle and run the machine. Then re-fill with water.
Double check the hose for any kinks or pin holes.
If this does not correct the problem,the water level switch will need replacing.
Aug 04, 2011 | Admiral AW22 Top Load Washer
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Water will not heat up why
Check your water supply line (wall) at the hot and cold hose connections to ensure that the hot and cold hoses are installed correctly. Your washer's water temperature is only as good as the temperature entering the appliance. Is water temperature o.k. elsewhere in your home? If not, your water heater may need to be checked for proper operation.
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
Washing Machines Logo
146 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
