Question about Mitsubishi MSZ09UN Air Conditioner
Mitsubishi msz-a12yv operation indicator light flashing - not pumping air. how do I fix it?
  • 86 Answers
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Posted on Mar 15, 2008
SOURCE: Timer set on remote, cancels out after use
I have discovered that a 7 day timer is available, but it is a fixed and separate box and will need to be programmed into the wall unit, at a cost of $500.As i am a pensioner and unable to afford this cost, I must persevere with the remote I have. Why can't the so-called experts provide a top of the line product in the first place?The last aircon unit I had was a Fujitsu, and that DID Have a very good remote enabling a programme of ON - OFF, On - Off in a 24 hour period. Thanks for trying to help.
Posted on Apr 22, 2008
  • 5 Answers
SOURCE: mitsubishi msz-a24yv air conditioner.keeps turning
a/c units have ways of protecting their major components. if you have a freon leak it could be shutting down on low pressure safety switch. or it could be overcharged with freon and be shutting off on high pressure, although high pressure safeties usually have a manual reset. therefore a low pressure
problem is more likely
Posted on Dec 10, 2008
  • 400 Answers
SOURCE: mitsubishi heatpump not blowing out heat.
One reason could be a shortage of refrigerant. Another could be incorrect mode selection? Or the reverse valve which changes the unit from cooling to heating is either not being energised or may be blocked and would have to be replaced.
Posted on Mar 09, 2009
SOURCE: need to find owner's manual for model msz-a12yv
ummi think u gotta go up take a left and a right then go right again then have *** with a ******
Posted on Jun 02, 2009
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
Mitsubishi air con msza24yv. when we turn it on to the heating mode the operation light keeps blinking and nothing happens
Wait 5 mins after turning the unit on to make sure it is not on a pre heat, and if problem is still there check fault code on controller
Jul 04, 2011 | Mitsubishi MSZ-A24NA Split System Air...
I have an air conditioner Mitsubishi MSZ-A26YV, it has stopped heating, even if it's on the heat setting [sun emblem] and is set to highest temp, only cold air comes out, otherwise it does all other...
It's not indicated to turn directly from cooling mode to heating mode. You must wait about two or three minutes before the change. After the spliter start, you must wait few minutes to get hot air.
Mar 30, 2011 | Mitsubishi MSZ-A24NA Split System Air...
I have a Mitsubishi mini split system heat pump model MSZ-A12NA. The problem is the wireless remote has been lost. How do I get another one? Or, can a regular hard wired heat pump thermostat be used? I...
just lift the filter panel on front of indoor unit and turn it on manually,remember this just sets the a/c to 24 deg,the unit decides whether to heat or cool it to 24 deg....at least it gets it goin so u can order a replacement
Feb 21, 2011 | Mitsubishi MSZ-A12NA Air Conditioner
Mitsubishi msz-ga60va not cooling. Did same last year then righted itself. Left light is flashing. and no cool air. Please help.
You didn't give any error code. But, still, I hope unit need complete service. Do it and check again.
Jan 07, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
We have a far-let LED flashing 1 second on 1 second off repeatedly indicating a communication error between the indoor and outdoor units. The practical outcome is that the outside condenser doesn't kick...
Call Mitsubishi Tech. directly...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Sep 03, 2010 | Mitsubishi MSZ-A12NA Air Conditioner
Need to find owner's manual for model msz-a12yv
Jun 02, 2009 | Heating & Cooling
Mitsubishi MSZ09UN Air Conditioner Logo
323 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
