My printer is out of Yellow ink! I only want to print black n white, but it does not allow me to print at all. The message reads - The printer does not have enough ink to maintain print quality. I have plenty of black, cyan and magenta. I have tried to to set my windows, Start, printer and faxes, right clicked on to properties and select black n white but it comes up with the same error on my printer. If you can help it would be great. Thanks, Damon
    Top Expert:
  • Office Equip... Master
  • 12,962 Answers
The printer will not work under the conditions you indicated. Manufacturer wants you to buy more of their overpriced ink.
U can try filling the yellow cartridge with some ink substitute such as alcohol, doing a hard reset of printer and also uninstall and reinstall software and see if you can fool printer to work.. If so, then you can change preference to just black and white.
Posted on Jun 21, 2017
  • 832 Answers
SOURCE: Brother Printer Cannot Print in Black
This could be because of several probs: 1. The ink cart is not original and wont let the ink flow, because the valve is not open. 2. There might be air bubbles within the capillaries. 3. The ink is not genuine ink and has pigments in it. Solution: see here, too: Insert another ink cart. Use, if possible, the genuine ink cart from brother. Do the cleaning cycle twice. This will extract the air bubbles out of the caps after the second time. If you dont have any success the printhead is clogged and cant be cleaned anymore!
Posted on Sep 17, 2007
  • 217 Answers
SOURCE: Colour balance
Original Samsung toners,or 'remanufactured' or home refilled ??
Is the 'background' (ie what should be white) OK ??
Posted on Jan 17, 2008
SOURCE: Cannot See Estimated Ink Levels on Printer Toolbox
I came across this similar problem and spent days trying to figure it out. I knew I was close when I tried to start the HPZ12 service and it kept failing with "unable to find the specified file". I traced it with a process monitor and found that it was looking for a registry key that was not present. Specifically:
HKLM\System\CurrentCosntrolSet\Services\Pml Driver HPZ12\Parameters
It was looking for the string:
which should be set to:
(or something similar).
The unfortunate thing is that no matter how many times you install and uninstall the HP drivers, then don't reset the registry keys for the HPZ12 service. In the end, I ended up doing the following:
1. Uninstall software and reboot
2. Go through registry editor and delete the PML key (just did a search for all PML occurences)
3. Deleted the c:\program files\Hewlett-Packard directory
4. Deleted the c:\program files\HP directory
5. Deleted the c:\windows\system32\spool\drivers\w32x86\ contents (anything that referred to an HP printer or driver)
6. Deleted the HKLM\Software\Hewlett-Packard registry key
7. Rebooted
8. Reinstalled and everything worked.
I suggest you backup any registry keys prior to deleting them in case you make a mistake. You can use the Export feature on the right-click context menu to save each key you delete, or use some tool to make a backup of your registry prior to making these changes. Similarly, for the files, I renamed directories or created backups of their contents.
Once I reinstalled, I found that there were TONS of new registry keys added that weren't there before. So the real problem is with HPs install/uninstall. It doesn't clean up properly and any aborted or failed instalation will leave the drivers in a poor state.
Hope that helps.
Posted on Jun 06, 2008
  • 66 Answers
SOURCE: magenta doesnt print in proper place
Sounds like the new cartridge has been sitting around for too long. The solid lines are usually due to the drum being exposed to light for too long. The other reason could be the charger roller has been in contact with drum (in the cartridge) for a very long time and probably heat has a part in it as well. Try another cartridge.
Posted on Jan 12, 2009
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Brother Printer-copy-scan-photo capture Model DCP-110C After replacing black ink and yellow ink, still says yellow ink low, and will just print out pink menu items, no message. I cleaned it 5 times. ...
place the printer cartridge into a small amount of water to make sure the yellow is flowing out. Let me know what this finds and try it again if yellow comes out.
Also, what exactly did you clean, the metal contacts?
Jul 03, 2008 | Brother Office Equipment & Supplies
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
Printing in just black and white
Epson,. has it rigged, that you must have ink in all the cartridges.............! Doesnt make a difference, if you are printing black and white ONLY.
You have to replace them.
Good Luck......
Dec 29, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Out of yellow ink but only want to print in B&W
please you use the coloue paper print other black and white paper print ?
but you use the only yellow paper print ?
you refling the colour cartridge and setting page in colour prints
and use printer.
Sep 27, 2009 | Brother MFC-260C All-In-One InkJet Printer
Can't print in black and white
Hi Aaron,
There should be a setting in your PREFERENCES that allow you to set it to black print only. Select it as your default setting so that you don't have to change the settings each time you print.
Hope this helps. Good luck!
Jul 31, 2009 | Office Equipment & Supplies
Brother DCP-145C Print in black and white..?
As far as i know it will not work for color print unless all the cartridges are full. It will still print in b&w- go to properties of your printing document and change to "greystyle" but this will only work if you don't/have not turned off the machine at the power point. Once the machine is reset it wants to confirm all new cartridges and wont allow a black print until they are all in and full. So you cant use cartridges that have run out to "trick it".
I'm not sure if this is the intent of brother ( my guess is yes) a design oversight or a genuine precaution measure for consistency by not letting the printing heads dry out.
The yellow always runs out first, so stock up on them if you do alot of color printing- but the cartridges only last for 6 months so don't go crazy.
Brother if your reading this- Most of us don't care about color~! We just need a printer for uni and information. Make it work on our price range please!
Apr 29, 2009 | Brother Office Equipment & Supplies
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
See here:
Sep 07, 2007 | Brother MFC 420CN All-In-One InkJet...
110 people viewed this question
