Question about Watches
How can i fix the second hand on a wall clock the hand just hangs down while the big hand goes around?
    Sergeant:
  • 302 Answers
  1. It isn't clear what hand you are talking about, but it doesn't matter
  2. Set the hand that is working to 12:00
  3. Place the loose hand at 12:00 and gently press it on. It is usually a friction type fit
  4. The hands should line up at 12, that is the goal
  5. good luck, Michael
Posted on Mar 16, 2011
How do I slow down a Benrus battery operated wall clock
The second hand may be slipping on the shaft or misadjusted. This is basically a press-on fit.
Dec 20, 2016 | The Watches
How to put hands back on battery operated wall clock
put the smallest one on first and the longest one second
Oct 18, 2015 | Watches
Need replacement clock hand
Your best bet is to see if the original manufacture of the clock is still in business. If so, they may still have the necessary information for one of their clock makers to make a new hand for you.
The only other solution is to locate a watch maker who specializes in restoration of old clocks and watches. There are many around who are very good. A new replacement hand can be made for you.
In any case, obtaining a hand will not be cheap. There will be a number of hours of work involved to make a new hand. The watch maker will most likely need the clock movement set to him so he can do the exact measurements required.
As for original parts off the shelf for old clocks, these are not easy to find. Many of these clocks were built on a one-by-one individual basis.
Jerry G.
Dec 04, 2011 | Watches
I have a big tic fossil watch. The flashing second is working properly, but the hand doesnt. It looks like slowing down. How can I fix this problem. Thank you
your watch has two batteries inside, the small battery is the one that had to be replaced. it is under the big battery, the small battery makes the minute and hour hand move while the big battery makes the seconds flashing. i hope that i had been helped you.
Aug 01, 2011 | Fossil Big Tic JR7896 Watch
Analog second hand freezes periodicaly, digital clock works fine
mcdevito75 here, Sounds like the seconds hand is bent and hanging up on the face. See the repair service directory her at fix ya, bottom of the page click on repair service directory the watches.
Jun 24, 2010 | Timex Expedition 84601 Wristwatch
I have a Westclox battery operated wall clock with chicken on face. The battery is new. The second hand tries to move but just "clicks" How can I fix this?
Sounds like it is just worn out.
Sometimes you can replace the generic clock works in these type of clocks. Go online and do a search for battery powered clock works, and see if you can match yours. They are removed quite easily after popping off the clock hands, and removing a nut under the hands that holds the clock works in the chicken.
Here's a link to a site that sells the clock movements... http://www.clockworks.com/
Jun 09, 2010 | Watches
Invicta model 3209 watch
Your watch is fitted with chronograph movement 5040D made by Ronda (Switzerland). If you take a closer look, then you will realise that the subdial at 3 o'clock is counting seconds allready. This is your seconds dial, not the big one.
The big seconds hand actually is the chronograph hand (stopwatch) and, when activated, works together with 1/10th counter.
Follow this link and see for yourself:
http://www.ronda.ch/e/index_bedienung.html
Find movement 5040D and click on INTERACTIVE version.
Rate me, please.
Mar 25, 2009 | Invicta 3209 Lupah Diver Watch
Wall clock not working
If you are sure the hands are not touching as they pass, perhaps the minute hand and hour hand are binding together at the hub. Try this: Gently pull on the minute hand by gripping its hub with the nails of your finger and thumb. It should slide forward a little (or come off). Also the same for the hour hand, to ensure it is not binding on the face of the dial.
I don't know the particular clock, but if it has a SECONDS hand, this is often the one that needs to be freed.
If all the hands are free, all should be good. If it has a seconds hand and the clock stops when this hand is going "uphill", try a fresh battery. If this doesn't fix it, remove the seconds hand and use the clock without it. Or you could try to counterbalance the hand by adding a little weight to the opposite side... this could work, but as it increases the mass of the hand also, it still might be a problem.
Another way might be to shorten the seconds hand..!
Feb 22, 2008 | Watches
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 06, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
323 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
