Question about Exercise & Fitness
I have life gear treadmill. Some times error message (E2) is displayed and the machine is off. Please give some solution.
    Sergeant:
    Champion:
  • 263 Answers
You need to recalibrate your meter
Posted on Mar 16, 2011
  • lali5 Mar 21, 2011
    What does that mean?
    How to recalibrate the meter?
  • Anupam Datta
    Anupam Datta Mar 21, 2011
    just compare with another and reset the meter and go to a calibration shop
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Sole f60 incline error E2
does the incline work at all. if not try to calibrate the incline. if this fails something could be wrong with the incline motor
Oct 20, 2014 | Sole Fitness Sole F63 Treadmill
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
Where can i download a manual for an image 10.4 treadmill? it displays an E2 or E4 error message. thanks.
Try Retrevo Manuals.com lots of manuals but you really have to search for them. Make sure you gave make, model number etc.
Dec 15, 2013 | Treadmill Doctor Image 10.4 Q Console...
E2 error code on my Tempo 612T treadmill
adjust and clean the speed sensor, and tight the connector very well, see the diagram
2) test the input voltage motor, if there are voltage the motor replace
3) test the output voltage board, if there are NOT voltage , the board is faulty, replace.
God bless you
Nov 11, 2012 | Exercise & Fitness
E 7 error code is displayed on my SportsArt 1210 treadmill. When keep it turned off for a long time, then the machine works fine but if I switch if off and back on again, E 7 is displayed and nothing...
i have the same treadmill with an error 10 message. i have the booklet that came with it and it says that an error 7 message indicates(too much to write). I can fax the error message page and the wiring schematic to you. my email is srt8ght1999@yaho.com. not posting my number here.
Jan 05, 2011 | Exercise & Fitness
Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
Jul 28, 2009 | Life Fitness T3 Treadmill with Advanced...
Exercise & Fitness Logo
679 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
