Question about Formac Gallery 1900 Oxygen 19" LCD Monitor
Backenlight inverter panel failure formac gallery 1900 oxyg
My formac monitors backlight assembly died.
I opened it up found the fuse f1 had gone open circuit.
I have replaced it with a 4 amp quickblow fuse.
Have you got a circuit sheet for this monitor.
I want to check its value for the fuse f1/
Mine had the same problem, replaced the fuse with a T2.5 amp.
Ammeter gave a reading of 1.6A across the fuse pads so we shall see if its pops...
Posted on Oct 18, 2008
  • marcin
    marcin Nov 08, 2013
    where is this fuse?
I need a new power supply for a formac 1900 monitor
I've got two and you are welcome to one if you pay pp plus a sensible offerI live in South London UK
May 19, 2011 | Formac Gallery 1900 Oxygen 19" LCD Monitor
Suddenly, after no previous problems, when computer (Mac- G5, older, not intel) started up in the morning, the monitor, although power light on, displays only black screen. Monitor is lcd Formac- not...
Try hooking it up to another PC first, but more likely to have failure in the power supply caps or failed inverter cicuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | Formac Gallery 1900 Oxygen 19" LCD Monitor
The monitor has power, but there is no picture. can this be repaired?
May 24, 2010 | Formac Gallery 1900 Oxygen 19" LCD Monitor
VX900 19 in. Flat Panel LCD Monitor: when i turn it on the screen is black....
You may have backlight inverter failure, check the fuse as shown in my pictures, you can also have bad backlight assemblies also, but check the fuse on the inverter bd first, verify that you do have 12v at the fuse.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/
May 16, 2010 | ViewSonic VX900 19" Flat Panel LCD Monitor
Why ismy screen is flickering?
You may have failing AC power supply adapter, backlight inverter board, backlight lamp assemblies (poor solder connection), bad soldering works, burnt parts. You will need to troublehsooting it to component level to repair it.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 07, 2010 | Neovo F-417 17" LCD Monitor
It work but no light
It sounds like the backlight inverter circuits have gone out, or the lamps assemblies.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 04, 2010 | Samsung SyncMaster 153V 15" Flat Panel LCD...
Power button lights up but screen stays blank
First you check the problem with monitor or cpu.you can check it by other monitor.after replacing the monitor it gives not display. then your monitor has any hardware issue.then you can repaired it from service center.
Mar 24, 2010 | Formac Gallery 1900 Oxygen 19" LCD Monitor
LG RZ32LZ55
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
May 22, 2008 | LG RZ-20LA70 20 in. LCD Television
Formac Gallery Monitor
Looks like the water is getting in to the LCD contacts. Or corroding them. If the monitor can be opened safely open it and place in a warm dry environment for a few days. Silica dehumidifiers may help.
If the issue is not permanent this may fix it.
Jan 27, 2007 | Formac Gallery 1740 Oxygen 17.4" LCD...
Formac Gallery 1900 Oxygen 19" LCD Monitor Logo
358 people viewed this question
Top Formac Computers & Internet Experts
David Payne
David Payne
Are you a Formac Computer and Internet Expert? Answer questions, earn points and help others
