Question about Karcher Garden
We have a Karcher 2.36M can you attach the karcher directly to a hose?
5 Suggested Answers
  • 3 Answers
SOURCE: Karcher Power Washer Problem
I had same problem won't build pressure. go to http://www.wmpcs.com/index.php?main_page=page&id=14 and see diagram. I pulled white plastic cover off top of pump (2 torx screws), remove main pump from gas motor otherwise you wont be able to get at the valve below. The important part is the valve below the the white plastic piece, it has a raised slot and mine was stuck in there. I used needle nose pinched together with pliers to lift it straight up. After wd40 and cleaning the hole and valve it should pop in and out easy. Put everything back mine worked like a charm after that. So at least I know what the problem is. Great powerwasher-I use for house painting part time and love it.
Posted on Jun 20, 2008
  • 92 Answers
SOURCE: karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
SOURCE: Karcher/Winner 11 - motor pulses when hose is not operating
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
Posted on Mar 12, 2010
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Hose keeps popping off... Brand new. Is there a method of starting up ? I attached the hose... On goes karcher...On goes hosepipe tap....the plop, off comes the pipe ? What am I doing wrong. It is attached...
The best thing is to get a complete pair of quick couplers. One male one female and replace the ones you currently have. Stick the male on the washer the female on the hose and as they are the same should be able to hold under the pressure of water.
Mar 24, 2014 | Karcher Garden
Hose out of the karcher unit blows off
Sounds like you need a new hose if it keeps blowing off the unit, see attached link to purchase the hose.
http://www.wmpcs.com/index.php?main_page=product_info&cPath=81_55_58&products_id=286
Oct 29, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
My karcher washer has lost most of its pressure it doesn't clean the bricks like it used to
The lance hose that attaches to the pressure washer keeps coming off when the power to the machine is turned on, i've only used this product four times since new in January this year.
Sep 06, 2010 | Karcher K2.26 Electric Power Washer
Faulty
water is pouring out of my 5 year old karcher from the trigger handle WHY???
May 22, 2010 | Karcher PSI Electric Pressure Washer
Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Jun 03, 2009 | Karcher G 2600 VH Gas Pressure Washer
Can't get the spray gun onto the hose from the washer...no manual
Your posting is incomplete, so I'm not quite sure what we're dealing with here.  I understand the machine and the high-pressure hose are Karcher - right?  Is the gun also a Karcher part?  If all are Karcher parts, they should fit unless the screw threads have been damaged.  If they are not all Karcher parts, they will not fit because Karcher connectors are different from almost all others.
Please post again if this doesn't help, giving as much detail as possible, and I'll see what else I can offer.
Apr 04, 2009 | Karcher PSI Electric Pressure Washer
I purchased the karcher for kids washer and can't connect to garden hose...is there some attachment neded??
there should have been an adapter from the factory on it. if not you can go to the dealer and get one.
Jun 28, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
