Question about Microsoft Windows Vista Home Premium Edition for PC
I want to know how to format a computer system
  • Microsoft Master
  • 1,381 Answers
Hello darlington4 ,
You can't format the supporting OS drive ( usally C ) but if your intention is to install a new OS version on your machine , just insert the install disc and follow instructions . The existing O.S. will automaticaly be erased .
Otherwise , you need to extract the drive from tour machine and format it with another healthy computer by connecting it via usb or as secundary .
Best regards ,
fanaudi
Posted on Mar 16, 2011
  • 302 Answers
Hi, it's very easy. Just buy a licensed Windows CD Installer.
Start your pc, insert the cd then upon boot up, you will be asked to press any key to boot from cd.
Just press any key then Windows installation will start.
Just follow the instructions on screen then you will be able to format your computer.
You will also be asked if you want to partition and format your hard drive. Just select if you want to or not then proceed with the installation.
The whole process takes about an hour depending on the speed of your computer.
Cannot open drive E on Iomega zip 100
Assuming you have connected the drive and then restarted the computer with the drive connected and powered on... if it is model 31714 (not the same as the picture no power supply is required - if power supply is required make sure unit is powered on prior to connecting)
First guess at your problem. Your disks are formatted for a operating system other than what you are using. (Mac formatted disks on a PC or the other way around)
If you don't know how the disks were formatted you could test this by letting it get to the "insert disk" and then trying to right click and see if you have a format option ... note this will erase all information on the disks.. you will likely need to long format
Second guess the drive is bad... have seen cases where the drive is bad. If you have another computer you can use try hooking the computer up to another computer and see if you get the same result.
Let me know if this does not work and specific model number and op system I might have more ideas. I can also point you to a replacement If I know more about your system.
Feb 20, 2015 | Iomega Zip 100MB (31714) External ZIP...
CF cards stopped working
You should try to format it to FAT32 not FAT only.
May 24, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
How to format mine (unable to format system storage(802E1002) ?
Not having my PSP in front of me and not knowing what model you have, or what kind of computer or OS you are trying to do this with, I believe there may be an option to format the memory card from the PSP itself. I believe there has to be an option somewhere on the PSP to do this. My reasoning is that if you put in a brand new memory card, it needs to be prepared for use in the PSP. In other words, the PSP installs files on the memory card so it *knows* how to communicate with it. Basically, it installs a file system on it, much like your computer does when setting up the OS.
--OR--
Pull out the memory card and plug it into a card reader that is hooked to a computer. Then, as it shows up on the *My Computer* screen, right click on the memory card and select format. Be sure you have the right card selected for formatting, or you could hose your computer.
May 31, 2014 | Sony PlayStation Portable (PSP) Console
SanDisk Sansa M230 Problem:When connected to my PC and try to open system says " this device is not formatted. Do you want to format it now?" . If "yes" is selected then system says it...
Connect your SanDisk Sansa M230 to your computer again. Ignore the format message and go to My computer icon on your computer, right click on the drive (E:or F: or G: etc) representing your SanDisk Sansa M230, scroll to format allow it format from there.
If it still refuses to format, you can the reset the SanDisk Sansa M230and try again.
In case you don't know how to reset your SanDisk Sansa M230, read the info on the below link on how to reset your SanDisk Sansa M23;
http://www.fixya.com/support/r6977146-reset_different_models_version_san_disk
I hope this helps.
Good luck.
Feb 22, 2011 | SanDisk Sansa m230 MP3 Player
Needs to format and I do not know how.
Hi
To format it Connect it to the computer, go to My computer-> right click on the mp3/mp4 player after it is displayed-> select format-> Format it as FAT32 File system. Formatting the MP3/MP4 player will delete all the songs/data from the player. So, backup all data before formatting it. Hope this helps...
Daniel
Sep 18, 2010 | Lexar MDA256-100 MP3 Player
My pen drive is in RAW file system, I ca'nt open or format it.
Try to get a software called parted magic. its linux based and you should easily format the pen drive.
U can also try HP USB Disk Format Tool.
May 28, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
WHAT DO I GO TO, TO REBOOT MY WHOLE COMPUTER LIKE IT WAS NEW AGAIN.
Format the hard drive and reinstall the OS. You will need the original Vista Disk or Vista Restore Disk you created after your bought the computer. Once you format the hard drive and reinstall the operating system it will be just as it was when you first turned it on. Know that you will loose everything on the computer when you format the hard drive. Back up what you do not want to loose.
Feb 07, 2010 | Microsoft Windows Vista Ultimate Edition
I hit a button , must have been a format button on my sansa mp3 player. my computer will not show it exists yet it charges the unit. please help.
May be its a wrong format type.
ok try to format it with fat file system.
Follow the steps below.
Go in Control Panel>Administrative Tools>Computer Management> A window computer management will appear. Then in the left column click disk management.
Format it with fat file system.
Tyr this and let me know...
Jan 28, 2010 | SanDisk Sansa Clip MP3 Player
Format my computer
You can format the computer with the restore discs that came with the computer or with windows installation cd. you can format the hard drive / computer in the setup, it will format the hard drive as you go forward, it will ask if you want to format fast or slow etc.
let me know if you need anything else.
Ekse
May 05, 2009 | Acer Extensa 4620 Notebook
Presario 900 -- How to format the system?
cant use recorvery ok u need to get xp cd boot into it says it all formatt then install new update ect
Feb 04, 2008 | Compaq 100GB Laptop for Presario 900 &...
Microsoft Windows Vista Home Premium Edition for PC Logo
152 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
