Question about Xerox DocuColor 3535 Copier
Sir I have a DC3535 Xerox machine I described my problem please help me . Sir I change two drum after that show the display board a fault 004-346 When I open the IBt Belt and re load Ibt belt and start the machine after that the display board show : Some feature may be unavailable A fault has occured, contact the system administrater. this massage will come the DC3535 Xerox Display board
2 Suggested Answers
wrinaldo
  • 185 Answers
SOURCE: how to change ibt belt
The error code 004-346 is an IBT home position sensor. The belt may be damaged or didn't move.
The sensor which is mounted on the frame looks at the belt to see if it made a full rotation. Perhaps the sensor is dirty or damaged. Maybe the home reflective mark is damaged.
The belt may be damaged or shredded. Find out why the old belt was damaged before you install another part!
You probably need to purchase a new IBT belt PN 802K208991. The Xerox technician has a proprietary laptop to clear the codes and calibrate the "Belt Edge." The belt is very fragile, so whoever installs it needs to be very mehtodical and careful.
These may preclude you from repairing that yourself.
Whit Item, Inc.
Posted on Dec 02, 2010
004 error code350
I am afraid that that foult code means that the machine's software has to be reloaded. The only way this can be done is by a qulified xerox tech. It need a laptop with special software to connect to the machine to do the download.
Nov 28, 2013 | Xerox CopyCentre C20 Black and White...
KUWIT OIL COMPANY IAM FACING PROBLEM IN FAX MACHINE BROTHER 2820 MESSAGE SHOWS 'TONER LIFE END' AFTER CHANGING TONER MESSAGE REMAIN SAME PLEASE GIVE ME SOLUTION. I HAVE AROUND 24 FAX MACHINES BROTHER...
you must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
Jan 26, 2011 | Brother Office Equipment & Supplies
Hie,am looking for a xerox M24 transfer belt at a cheaper price.Can you please help.Peter
One of the best prices I have seen and they have the best aftermarket support for Xerox.
http://www.partsdrop.com/belt-64k91451-xerox-style-dc3535-p-1782.html
Good Luck with your Xerox and Thank You for using Fixya.
Jan 11, 2011 | Xerox WorkCentre M-24 Color Copier
Dc3535 has an error code 102-319, 102-372 and machine also hangs after the code is displayed
u just try one thing
remove ur fiery power cable
and power on machine
if u make the xerox copies from the machine then issue with ur fiery software
or
if problem is same with this
then issue with ur ess software
i guess
Dec 19, 2010 | Xerox DocuColor 3535 Copier
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
I have a EX-3535 fuser error code 004-361 coming up on a new fuser on a machine. I changed the fuser for another new one and still get it so suspect I need to do an NVM setting but don't know which? Can...
4-361 Drum Motor
Drum Motor failure.
Initial Actions
• Remove all Drum Cartridges.
• Perform REP 1.6.
Procedure
The machine is a DC3535.
Y N
Enter dC330 [004-003] and press Start. The Drum Motor energizes and the drives
rotate.
Y N
Go to Figure 1 of this procedure and measure voltage between the Drum Motor P/
J210-4 (+) and GND (-). +5 VDC is measured.
Y N
Go to Figure 3 of the +5 VDC Wirenets and troubleshoot the problem.
Replace Drum Motor (PL 1.1).
Dec 01, 2009 | Xerox DocuColor 3535 Copier
Xerox XD100 that is showing a code J2
No. The CRUM is integral to the Drum Cartridge. The only way would be to swap CRUM from a cartridge that failed for a reason other that it reached end of life.
Jul 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Fault E05-02
Hello sir; According the manu, the error you display,it means 12 volt low voltage power supply board have problem, change it.
Apr 28, 2009 | Panasonic DP-C264 Copier
Error... the Fiery Server Interface timed out, please, check the Fiery
Sir, I have Document Centre ColorSeries 50 In this machine Scanner is not working, in the Machine Display showing : Error... the Fiery Server Interface timed out, please, check the Fiery. Please help me
Sep 24, 2008 | Xerox DocuColor 12 Color Copier
97 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
