Question about Refrigerators
I have a electrolux model no. Rm185R 3 in 1 fridge gas 12v ac100v 41 litres. fridge works well but the 3 push buttons that switch between gas,mains power and 12volt has jammed and broken beyond repair. help i need a new switch?
5 Suggested Answers
SOURCE: Hi i have a 3
A simple remedy to the fridge working correctly.
I wasnt aware that the mains dial turned fully to an 'OFF' position. Once I had turned the dial until it 'clicked' off, I tried the gas and it lit and cooled perfectly.
Posted on May 29, 2008
  • 159 Answers
SOURCE: maintenance
there are nothing to service on this type of fride but is almost the best type
Posted on May 16, 2009
  • 3 Answers
SOURCE: electrolux fridge in my caravan will run on gas,
Hi it sounds time to pull it out and give the ignition box a good blow out to remove dust and cobwebs. Also remove the jet in the supply pipe where it screws on to burner box. Just wash and clean it dont poke anything in the jet hole. Graham
Posted on Nov 13, 2010
walterkunesk
  • 683 Answers
SOURCE: my fridge will only work
Your refrigerator has a freon that we call R-717 which is amonia. You have to heat the amonia to have refrigeration. using the 12 volt side will cause power drain on batteries. If you had to close the gas valve most of the way down this is telling me that he gas pressure regulator went bad. The 220 volt heater is still working that is why this is working. change the regulator and you should go back to gas for operation. If the helps give me a rating please. thank you.
Posted on Apr 08, 2011
Testimonial: "Thank you for your reply. The gas is now working at the correct level but the fridge still will not cool on 12v or gas only still 220volt. Regards Nic"
Hi just bought campervan which has an electrolux rm 2200 fitted we are unable to use it on 12v but works well on mains.
was the engine running on vehicle when you tried to operate 12v mode. From the user manual it needs the fridge cooled down on gas or mains first and it will only operate at 12V if the engine is running to prevent vehicle battery running flat.
Aug 13, 2014 | Refrigerators
My caravan fridge will not work on mains or 12 electric but it dose work on gas
The 12v power supply on the fridge takes a lot of power, and can only be used when you're driving. (When the engine runs.)
Regards,
Jul 09, 2011 | Electrolux Refrigerators
I have a 2453 150 litre caravan fridge not working on 240 but works on gas. What maybe the problem and can i get a mobile repairer
It sounds like the electric heater is not working as you say it works on gas, so the expensive bit is OK.
An appliance engineer should be able to get the spares and fix it.
Mar 07, 2011 | Microwave Ovens
Electrolux 3 way fridge will not work on 12v or 240,switch lights up, ok on gas. can i repaire?or have i got to replace? i think the model No is rm4200 or rm4230
Hi My three way fridge has the same problem. Have solved the 12v problem as it was not wired to the 12v invertor. Do you have an on board battery supply? the 12v is usless and runs a battery flat in no time. Better off to use gas. Hope to have the electrician here next week to check 240v so will let you know if we find a problem. Graham.
Jul 07, 2010 | Electrolux Refrigerators
Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Apr 12, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Dometic rm2652 frige just stopped working, gas nor
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
Aug 22, 2009 | Refrigerators
Fridge in VW camper van
CHECK appliancesfactoryparts.com
Jul 26, 2009 | Refrigerators
Hi i have a 3 way electrolux fridge. it cools perfectly well on the electric mains, I've not tried the 12v, but it fails to cool on the gas. The gas ignites but fails to cool the system.
May 28, 2008 | Electrolux Refrigerators
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
