Question about Makita Garden
Looking for an armature for Makita 2400B Mitre saw.
    Sergeant:
    Champion:
  • 250 Answers
Hello I would look on ebay or craigslist for the armature. Just type in make and model armature.
Posted on Mar 16, 2011
Instructions on replacing a 10 inch makita 2400b miter saw with an irwin replacement blade - comes with spacers but not sure what goes where
the spacers are used to make the hole in the blade fit snugly on the shaft
replace the blade in the same way that it was taken off
all you have to do is mount the blade with the arrow facing the direction of rotation
Jun 17, 2017 | Makita Saws
Why doesn't the laser marker work on my Makita mitre saw?
contact Makita, it may be defective
, or they can troubleshoot. You can check on youtube.com for a possible fix also.
Mar 07, 2015 | Makita 10" Miter Saw LS1030N
What keeps a makita reciprocating saw from starting?
It could be several things:
1) Brushes - easiest to check, most Makita models are accessible from the outside through round caps on either side of the tool. Check to see if the brush springs still have good recoil and the brushes themselves aren't chipped or burnt.
2) Switch - you will need a multitester to check the switch. Using the continuity setting, check to see if you have continuity through the switch when the trigger is depressed.
3) Armature - if the armature has failed you most likely would have also found the brushes badly burnt or chipped. You should be able to get an idea by looking down the brush tube with a flashlight and looking at the condition of the armature - it may appear slightly black, but should not look burnt or have unusual spaces between the commutator segments.
Let me know if you need further help.
Aug 19, 2014 | Makita JR3030T Variable Speed...
Mitre saw blows breaker
bad cord, switch wired wrong, or bad motor. Pull the cover off the motor. Disconect the power. Sping the balde by hand and look at the bars on the comm, end of the armature. They should be evenly colored and the spacing between them should be even and clean cut looking. If there is heavy discoloration on one or two bars or heavy pitting between a couple bars the armature is likely bad.
Jan 02, 2014 | Dewalt DW715 Heavy Duty 12" Single -...
I can not remove armature caseing from makita miter saw
The casing at the saw end will have an inside case that is bolted either from behind the gears or from the armature side by screws. This has to be undone to allow the bearing to separate from the case
Jan 16, 2013 | Makita 10" Compound Miter Saw LS1040
MAKITA DROPSAW MODEL 2400B HOW DO I CHANGE THE BLADE
There is a push-in lever located between the handle and saw blade.
Push in lever and rotate blade until blade locks.
Once blade is locked, loosen nut located in center of blade.'
Before removing blade, notice direction of teeth.
Install new blade with teeth going same direction.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 18, 2011 | Makita 10" Miter Saw LS1030N
I have a Makita 10 inch compond mitre saw. My owners manual has been lost and I need the tables that show what degree to set the mitre and bevel for various degrees.
You can get it at Makita.com, type in yr modal number in the search bar, download a parts breakdown or a manual, if not u can order a new sticker from makita.
Jun 08, 2010 | Makita 10" Compound Miter Saw LS1040
Need wiring diagram to check continuity on trigger switchfor makita 2400b
If you cannot find wireing diagram,just have the saw unplugged and take one of the wires connected to the trigger off. Then by useing an ohm meter you can check for continuity.
Feb 21, 2010 | Makita 10" Miter Saw LS1030N
My makita sliding mitre saw is off a few degrees How do I adjust...non laser...10''
move the blade until it is square to the fence then loosen the screws on the table with the degree increments and set to zero.
Nov 19, 2009 | Makita 10" Compound Miter Saw LS1040
Need to re assemble trigger of ls1040 mitre saw, is there any instructions
go to MAKITA TOOLS.COM under benchtop on the menu select miter saws and your model number once in there there is a menu showing instruction manual, parts assembly and you can geta full print out diagram of how it should go together
May 03, 2009 | Makita 10" Compound Miter Saw LS1040
Garden Logo
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
