Cell Phones Logo
Posted on Mar 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My screen won't move and anytime I press something it does not move the screen does not move only when i press the button off screen the screen don't move i can't text
Level 3:
  • Cell Phones Master 17,130 Answers
  • Posted on Mar 16, 2011
Cell Phones Master
Level 3:
Answers
17130
Questions
0
Helped
3633175
Points
52372
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
My dsi won't work!
huh........I don't mean to be rude but that is unfixibale-sorry
Bios screen won't appear
You have to press the correct button on first start up - before windows starts. but as you don't give a lot of info I cannot be more specific.
How do I find the security code for my Matsui VP 9606 VHS Player
Try this
Unplug from wall for 30 minutes, then plug it in again. Power it on, and then PRESS CH UP & REC/QTR BUTTONS TOGETHER on your machine ~ (haven't tried it via the remote) Should then come up as "Pin OK" on the blue screen
I don't think it will give problems after that. Should stay unless you unplug for 30 minutes, the buttons won't reset the video.
My print activity says something is being deleted but it won't delete
Clear NV RAM.....
Unplug the Power Supply from the Printer....
Press and Hold the #5 button on the Printer and plug in the Power Supply.......
Don Release the #5 button till the Printer turns on completely....
After releasing the #5 button........
Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted......
It will not show that message again.
Good Luck!!!!
4helpful
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
2answers
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Hi my sunroof won't respond to the button when pressed. No sound of a motor moving either. What could it be??
check if you have 12V in the motor. If you have it it's the motor. If you don't have it check the switch and the fuses.
HOW DO I SET TIME AND DATE?
The Date & Time have been reset message appears after the Language screen the first time you turn on the camera. It may also appear if the batteries are removed for an extended time.
  1. SET DATE & TIME is highlighted. Press the OK button.
    (Select CANCEL to set the date and time at a later time.)
  2. Go to Step 4 below, Setting the date & time, anytime..
  1. In any mode, press the Menu button.
  2. Press autourg00205001id1456505.jpg to highlight Setup Menu autourg00205001id1561971.jpg, then press the OK button.
  3. Highlight Date & Time, then press the OK button.
  4. Press autourg00205001id1474816.jpg to adjust the date and time. Press autourg00205001id1474821.jpg to advance to the next setting.
  5. When finished, press the OK button.
  6. Press the Menu button to exit.
4helpful
Program date and time on the microlife bp monitor
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
2answers
How can I change the Resolution?
Olympus has its own way of showing the resolution settings. It is OK once you get used to it. Turn the Camera On. (On the back you will see an OK button surrounded by 4 arrows.) Press the OK button to bring up the menu. Press the left arrow button That should bring up a choice of: TIFF, SHQ, HQ, SQ1, SQ2 Use the up/down arrow buttons to move the cursor to SQ1 Then press the right arrow button That should bring up a choice of settings. Use the up/down buttons to select a setting. I suggest you select 2048x1536 (which is 3 megapixels) Then press the OK button. ................ You should think about getting a memory card with a greater capacity.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
