Question about Bosch Dishwashers
Hello, I have a washing mashine (BOSCH MAXX WFL 2860), just a few years old. Right now it wont start the centrifuge at the end of the programme, it will just deliver a strange, low grinding sound. Is this something that can be fixed? A common problem maybe with a common fix? regards, Thomas
SOURCE: Bosch Excell Dishwasher
Re: the gritty residue Check your spray arms. My Bosch arms clog regularly with little things. I have to unscrew the arm and run water through. Then I must pull out the food particle - usually a seed or kernel. Very frustrating as I do scrap garbage off before running the cycle. Would I buy another Bosch? Nope!
Posted on Jun 24, 2007
  • 641 Answers
SOURCE: Bosch Dishwasher Fails to turn on
It sound as a control board problem. you may be able to get it tested, and if faulty, get a re-worked (repaired one) much cheaper than a new one. Good luck!
Posted on Sep 13, 2007
  • 14 Answers
carry out a reset.
This should reset the board back to factory settings,
Deep Diver
Posted on Jan 17, 2008
SOURCE: Bosch Maxx WFL 2850 - the drum will not turn around
Check the electronic board for a short.
Posted on May 31, 2008
SOURCE: MDC4650AWW Portable Dishwasher
We've had a similar problem. A banshee screaming noise that's makes the skin crawl. Since our machine is well out of warranty I took the insides apart and found only a few cherry pits. (Lesson learned, always scrape your dishes before loading.) We covered out ears for a few minutes and the bad, bad noise went away. But the noise came back, it didn't stay away.. So here's what I found with more tinkering.
1. Problem: Small hard things can get lodged in the food mill/grinder assembly at the bottom of the dishwasher tub. It's there to cut up the big chus of organic matter I presume.Today I found a thin piece of plastic about an 1" long that got caught and was resisting being ground(even though we know resistance is futile) by the grinder thing. Anyway, I took the offending piece out, put it back together and the machine is working fine. I have a hunch that the first instance may have been one of those stray cherry pits that broke up enough to get caught.
2. Solution: take apart inside assemblies to get down to the "foodmill" like thingie and see if there's something hard organic or unorganic causing the noise. Discard. Put back together and hope that solves it. (It did for our machine)
3. What's needed? Good knees or a decent knee pad and a few simple tools as follows:
A. 1- medium flat blade screwdriver
B. 2- TORX screwdrivers, # T-15 and T-20, or equivalent bits for a portable electric drill/screwdriver.
C. Small pair of regular pliers or simialr tool.
D. Muttering under your breath like Fred Flintstone, or not.
4. Process:
Take out the water jet assembly. It is held by a clip at the back and top. Use the screwdriver to pry the tabs away from the clips, then pull the assembly out at the bottom where it connects. It's a simple slide in/out fit. The bottom whirlygig water jet is fastened with a threaded cap that can be removed with the pliers. (BTW, this can get clogged with gunk. while you have it of check for gunk. Then, keeping track, remove the remaining hardware with the TORX #T-20 screwdriver until you get to a round black piece. The black piece has to come off before you can remove the piece with the filter and grinding screen. Use the #T-15 bit for removal of the black piece. Then remove the rest 'till you see a "blade". Hopefully in that process, whatever was causing "the noise" will fall out and you can discard it. Observe how gross it is in there, shudder, and begin the process in reverse.
I do have some pictures of the process in stages if you want. E-mail me at: gpfn47atyahoo.ca (note: please use the "@" symbol to replace the "at")
Well, that's it. I hope it helps someone.
Have a Blessed New Year!
Greg F-N
Posted on Jan 06, 2009
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Washes until before rinsing and stops.
I think the problem was a bad waterfill value. removethe water from the base
RINSE/DRY = Water filling fault (over or under filling)
regards
balisonu79
Jan 04, 2010 | Bosch Washing Machines
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Bosch Dishwasher Maxx classixx Model S9H1B Lights stuck on end and last program.... will not reset nor start Think it just needs resetting ...but how?? Was working fine up to now Regards M
look carefully at operating buttons they will have 2 marked with a line with dots at either end, open door press and hold these 2 buttons usually 2 and 4 as from left too right, turn on keeping fingers on these buttons after a few seconds end light will come on turn off at main switch then back on again should work after that.
Nov 10, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
Jul 21, 2009 | Bosch Washing Machines
Need instruction manaul for bosch wfl 2260
Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
May 17, 2009 | Bosch Washing Machines
Bosch maxx 2860 won't do a quick wash anymore
The timer sticks at one place.
Quite a common problem. The least common is the actual failure of the timer itself. It is much more commonly caused by the failure of the heater, water valve, pump, a broken wire or even a blockage in the pressure system or waste system.
Mar 20, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
hi there sounds like a simple case of worn carbons cost about a £10
Jan 11, 2008 | Bosch Exxcel WVT 2850 Front Load Washer /...
Dishwashers Logo
49 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
