Here's the link to a solution voted best on Yahoo Answers posted 2 years ago....
http://answers.yahoo.com/question/index?qid=20090421170116AANlCxY
The solution requires the Vista disk(s) that should have come with the system.
You would use the format command from that disk to format the C: drive.
The formatting will either correct or lock-out any bad sectors that are found.
Then you would install Vista which would re-enable the F8 key sequence.
This allows a repair in which you can do a Dell Factory Image Restore from
the hidden partition so that the system can be returned to the company pool.
If you can't find the Vista disk(s), ask your company's support for the disk(s).
As you r telling blue screen is the result pf hard disk problem it is due to worm ifecting the MBR-Master Boot record
so use the tool provided below to rewritete MBR
http://www.avira.com/en/support-download-antivir-boot-sector-repair-tool
if still the problem persists let me know
if you are happy with my solution please rate me high and vote for me
WHAT CAN CAUSE PC RESTORE TO FAIL?
If the hidden DSR (Dell System Restore) partition is removed
If the MBR (Master Boot Record) is modified in any way (such as if you load the Vista Upgrade over XP)
If you change the MBR but the pointers to the DSR partition are left, the DSR will boot, detect that the MBR has changes, and flash a screen that informs you that the MBR has changed and that image restore will not run
If you create additional partitions, changing the MBR, Dell PC Restore will be disabled to prevent it from overwriting these partitions that may contain critical data during a restore operation
If you add a second SATA drive and migrate to a RAID array using the Intel applications accelerator in windows, running PC Restore will put the image back on C:\, but the system will not boot since the boot sector is looking for the ATA driver (factory image) and the bios is looking for the RAID driver (migrated configuration)
If any of these occur, you cannot set the system back to Factory condition. You must manually load the operating system, drivers, and all application software.
