Question about Broan-NuTone Allure II QS230SS Kitchen Hood
Performance ring for blower wheel
Where do I find a performance ring?
  • 38 Answers
1-800-363-0566 Inventex inc Montreal,qc
All the ring does is reduce the fan performance by about 25% Its a thin aluminium inch and a bit width.
Posted on Nov 06, 2008
I have a c1032 abs code, what is it and how do i fix it. 2006 Jeep Liberty 4x4
Right Rear Wheel Speed Sensor Signal Erratic Performance . Videos on youtube showing how to test the sensor , plus check tone ring .
Aug 15, 2017 | Cars & Trucks
Heating element on a maytag
The most common problems with a gas dryer can be Blown fuse on blower housing clog lint causing excessive heat, open flame sensor, open ignitor, faulty solenoids that sometimes work once then quit then work again after a long cool down. The blower wheel is plastic. They wobble out over time and cause a drop in airflow resulting in very poor performance. That is about all the smart pills I know. Here is how it works and how to replace them pesky coils a home movie from me.
Nov 20, 2013 | Maytag MDG7758AW Gas Dryer
My car have 1.5 engine and have 14 inch stock magz and tire size,can i change to 17inches without any problem with transmission and engine?
My experience tells me NO! When you MODIFY the wheel base with tires/wheels which were NOT designed/engineered for that vehicle, you CAUSE other problems which (to laymen) are UNPREDICTABLE. First of all, the braking system and its performance are compromised (meaning, the brakes will require more pressure/performance to stop/slow the vehicle - number one issue.) The larger wheel/tire assembly will require an EXPERT to properly 'ALIGN' them... OTHERWISE you could end up wearing out tires before their life-time. Whenever one modifies/changes an original vehicle configuration (wheel base, braking system performance, wheel alignment specification, etc.,) one takes/accepts the risks/outcomes of those modifications -- talk with (not to) the experts. Someone wants to sell you 'custom' wheels???.... when in doubt, find OUT!
Feb 08, 2011 | Hyundai Accent Cars & Trucks
My dryer is taking forever to dry clothes. Very damp and a lot of condensation when I open the dryer. It's model # MDE508DAYW
Good day,
Sounds like the vent system is badly blocked, the blower wheel has stripped off it's shaft, or there is a lot of lint in the blower wheel/lint screen area.
1. Remove the vent hose and see if your getting air moving thru smarty. Maytag moves a lot of air. If O.K. test dryer with vent off for performance. Clean or replace vent hose as needed.
2. Blower wheel sheared on it's shaft. You have to remove the front panel to see if the wheel is loose. Old version had 2 screws on the bottom of the front panel. Remove, disconnect door switch wires and remove. New style (no screws on bottom) requires a putty knife forced on each corner of where the top meets the front. About an 1 1/2 inch in from the edge. Force in, releasing clip, and pulling the top of the front panel toward you. Lift off.
Should the blower wheel be bad, replace but make sure the area between the blower wheel and door filter are cleaned.
Feb 28, 2010 | Maytag Dryers
Toro gas leaf blower erratic engine performance
change the sparkplug or seals.
Oct 04, 2009 | Garden
The blower wheel is making a lot of noise. How do
Remove the front face of the dryer and continue to disassemble the dryer until you have access to the blower wheel. The blower wheel is manufactured with a D shaped hole in the middle. If the whole on the inside of the blower wheel become rounded, then the wheel rotates at a different speed than your motor, causing the loud vibrations you have been hearing.
Using the pliers, remove the holding pin & blower wheel clamp. The clamp is the green ring and the pin is the small horse-shoe shaped pin with an arrow pointing to it.
Pull the old blower wheel off. You should see that the whole in the center is round rather than D-shaped.
Put the new blower wheel in place.
Replace the ring clamp & holding pin.
Re-assemble the dryer.
Sep 01, 2009 | Amana Dryers
How to clean the blower wheel/housing
Yes you can.
Steps for allure 2/qs2 3/qs3
blade located to the left (squirrel cage)
1.remove filters
2.remove both screws retaining metal plate underneath filters
Now you have room to remove the blade completely for washing.
The blade is only held on by pressure (no tools needed)
When re-installing, make sure the plastic lever on the blade is securely located in any hole on the motor face.
For allure 1
Blade located dead center of the hood
1.Remove filters
2.Remove pin
3.Remove blade (only held on the pressure) you may have to pull hard
4.When re-installing: make sure the flat side of the hole in the center of the blade is alined the flat side of the shaft of the motor.
Jan 30, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Broan allure performance ring
Are you looking for the metal ring which goes around your blower wheel. If so, we do have it at Inventex. All it does is cut down the performance of the fan. You will also need carbon filters to absord the smell.
Call us at 1-800-363-0566 Inventex
May 14, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Qs3 performance ring band
You only need that ring if you dont have an exit. All it does is take away from its sucking capabilities. I do service calls for broan & Nutone
We have the part:
Dec 18, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
355 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
