Question about Simplex Kaba Ilco Unican L1000 keyless lock
Lock has a Best core in the outside handle but door cannot be locked
  • 963 Answers
I recommend that you contact Kaba Ilco directly for technical assistance.
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
good luck!
Posted on Nov 05, 2011
Cannot open rear drivers side door from outside or inside. door panel is off, door is closed. child lock is on. tried pulling cable, wont move. tried lifting up the child lock with a thin blade
Sounds like the lock mechanism is stuck on the locked position. Since you didn't specify make and model this is a best guess. Make sure the lock is in the unlock position and try manipulating the rod connected to the outside handle (since child lock is on the inside handle won't work)
Oct 07, 2016 | Cars & Trucks
Door lock assembly
Toyota Corolla 1988-1997 Repair Guide Door Locks - REMOVAL & INSTALLATION
(see Figure 1)
  1. Disconnect the negative battery cable.
  2. Remove the door panel and watershield. Remove the service hole cover.
  3. Disconnect the door outside opening linkage. Remove the two mounting bolts and remove the door handle if in need of replacement.
Fig. 1: Power door lock control system component locations
  1. Disconnect the lock cylinder control linkage.
  2. Remove the lock knob and the child protector lock lever knob.
  3. Remove the lock assembly retaining screws and remove the door lock. If equipped with power locks, disconnect the electrical harness.
  4. To remove the lock cylinder, remove the lock cylinder retaining clip and pull the cylinder from the door.
To install:
  1. Coat all the door lock sliding surfaces with multi-purpose grease.
  2. Install the outside handle with the two retaining bolts, if removed.
  3. Install the door lock solenoid linkage to the door lock.
  4. Connect the link to the outside handle.
  5. Install the lock knob and the child protector lock lever knob.
  6. Install the door opening control link tighten the mounting bolts to 48 inch lbs. (5 Nm).
  7. Install the door lock cylinder control linkage.
  8. Install the door panel and watershield.
  9. Reconnect the negative battery cable.
Hope help with this; remember rated this post and thank you for using Fixya.
May 20, 2010 | 1991 Toyota Corolla
94 chevy lumina apv door will not open most of the time
since it is the drivers front door it could be the outside door handle , the rod that goes from the handle to the lock asbly or the lock asbly its self take the door trim panel off and then loos inside the door and latch the door with the door open. open the door with the outside door handle and watch the rod and the lever that the rod is pushing down the lever might not be pushing the lever down far enough to release the lock. If the lock does not open try pushing down on the lever and see if the lock releases if it does ck the outside door handle for cracks along the hinges of the handle I have found that most of the time that it is the outside door handle cracked and the rod is not moving the lever far enough to release the lock.
Feb 20, 2010 | 1994 Chevrolet Lumina APV
1997 Geo Metro rear door won't open!
I have the same car, same problem. I've still not been able to fix it, despite taking the inside panels off the rear doors, checking the rods were seated, applying WD-40 to the lock mechanisms, and manually working the mechanism. Child locks are not engaged, but I tried putting them on and off too. Just won't open.
Feb 19, 2010 | 1997 Geo Metro
97 Passat left front door won't open from outside - will open from inside if lock knob is pulled forcefully. I have new outside handle (not yet installed). All locks open properly with key. I have sought...
Hi.
Heat will not help and can damage the door lock mechanism further.
You can try lubing the door lock, but I do not thing it will help. I think there may be something wrong with the mechanism, or you will get the same problem from outside and inside.
If the door is opening from the inside , then the door lock mechanism My still be working. On VW the outer handle is connected to the lock by a steel wire, or by a metal shaft.
To access the door lock you need to remove the internal door panel. The door panel is held by hidden screws located on handles and by a set of clips located behind the panel near to the panel border.
I have service manual for several VW models, I will see if I can find the manual for 1995-1997 Passat and I will eventually send the diagrams to undo the door and access the lock.
Dec 30, 2009 | 1997 Volkswagen Passat
Need to lock ''one handled'' Bilco basement door from the outside
Buy a screw on lock pad from a hardware store, or call a lock smith to come take a look or give you advice.
Aug 20, 2009 | Locks & Locksmithing
2000 GMC Sierra passenger door won't lock
The Actuator is not functioning anymore, check to see if there is a fuse for it first. If that is ok then remove the actuator and test it outside using some wire and your car battery to see if actually moves or doesent this will tell you if you need a replacement.
Jul 15, 2009 | 2000 GMC Sierra
Honda Accord Outside handle broken and Child lock is on.
Remove the panel and disable the child lock or some cars have an option to just bypass the child lock either or
Jun 07, 2009 | 1999 Honda Accord
Outside door handle broke and child lock on
get a locksmith he or she should be able to open the door through the window.
Dec 14, 2008 | 2002 Hyundai Accent
Door lock
When the actuator moves the latch up, it connects the outside door handle to the opening mechanism. When the latch is down, the outside door handle is disconnected from the mechanism so that it cannot be opened. So in this case your latch needs to be replaced, the latch or one of its parts is malfunctioning. the outside handle is never beening disconnected from the latch. remove the door panel visually inspect for damage, and take the proper repair
Jul 12, 2008 | 1997 Oldsmobile Cutlass Supreme
Simplex Kaba Ilco Unican  L1000 keyless lock  Logo
80 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
