Question about Whirlpool GU2400XTP Built-in Dishwasher
Our Whirlpool Quiet Partner II stopped working! I can't cancel out the cycle, it has a flashing "clean" light, that flashes 7 times, rest, and then resumes! It will not turn on, only flash "on" and then nothing! Can somebody tell me if I need to call the repairman, or by a new one?
  • goldiesmom Mar 16, 2011
    I just found this solution on the net and it said to hit the normal wash, heat dry, normal wash, heat dry, normal wash, heat dry, normal wash, heat dry (4 x total). All the lights came on then hit the start button until the normal shut down. I did this, and it re-set the washer. I have run the dishwasher, empty, and it seems to be working. Not sure if this was an absolute fix, but so far so good! Will post more after it finishes this normal run cycle! Thanks for the help Bigg!
I have a whirlpool quiet partnerll and when i press on the start button it starts washing but after 5 minutes it stops and starts back up and starts again and again what could be the probleme.
jason jason06@live.ca
Posted on Apr 29, 2011
  • 333 Answers
Not positive, have you tried turning the circuit breaker off for a minute or two then back on? See if it will reset itself? Just trying to help.
Posted on Mar 16, 2011
    Hi Bigg,
    I unplugged the unit for about a minute, and it went right back into flashing, "Clean". When I hit the cancel button, it runs through the drain cycle, and the whole time it is doing that the "clean" light flashes for 7 flashes, then stops, and then starts again. When I hit the start button, it only flashes and then stops, but the whole time, the "clean" light is doing it's flash thing!
Whirlpool quiet partner ii clean light flashing 7 times. I installed a new heating element and reset the code, and it still flashes 7 times
Check the main control for the heater relay, this may be faulty and the cause of your issue. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 30, 2016 | Whirlpool Dishwashers
Whirlpool Quiet Partner II clean light blinks 7 times
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Mar 02, 2012 | Whirlpool Dishwashers
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Mar 12, 2010 | Whirlpool Dishwashers
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Constant flashing clean light
count the blinks shoud be 7 times it blinks then a pause if it does that its a heat circute problem need to check the heater and replace the controls
Jul 13, 2009 | Whirlpool Dishwashers
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Apr 09, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
580 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
