Question about Water Skeeter Guide Lite Pontoon Boat
Where can i purchase a valve for my water skeeter, the top pulled off of mine and the little spring got lost. thanx ,
I am looking for the same thing!!!!
Posted on Jun 20, 2013
2 Suggested Answers
SOURCE: 2005 Water Skeeter Pontoon..What kind of pump for the valves
If you look up Halkey-roberts valves you will see the air filler part.
Posted on Jul 14, 2012
When started makes sound but no water flows in. Hose looks ok
The most comon problem is a water input valve that gets plugged or the input strainer. The valve uses a tiny pintle pulled by a solenoid that opens a small orifice which then moves a diaphram that opens the main valve seat. A small piece of contamination can plug the little orifice so valve won't open. USUALLY you can take valve out and clean the little screen where the water comes in and disassemble and clean the guts of the valve. Be careful to NOT lose the little spring behind the pintle.
Oct 29, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
My mukka is shooting steam out of the small valve/washer thing on the bottom pot part. As it gets hots the valve pops up (but not with gusto like it used to do) and then I get a little coffee mixed in with...
I had the same problem and saw this solution in another bialetti mukka problem report, which made sense: "the safety valve on the lower boiler chamber is there to release pressue in case too much prssure builds up in the pot when brewing. If youy have an 11 mm wrench you can take it out and clean it by pulling on the outsidepart, there is a little knob that may be grabbed by a tweezer, gently pull it out, it is spring tensioned, and run water in the opposite end, Chances are some coffee grounds particles got in it and it is not seating good. after cleaning put a few drops of olive oil in it , the inside part. Should seal better and still funtion as a safety valve. Or you can leave it in place in the pot and just pull on the outside , flush with water and then put a few drops of olive oil in it. While you are at it, put olive oul on the threads, olive oil film and the the rubber seal and add a little to the rubber button on the top valve."
Jun 17, 2011 | Bialetti Mukka Express
The coffey is coming out very slowly. i don't know how to clean the water filter/valve. thanx.
try pulling the filter plug out of the water tank run viniger through it and clean the tank were the coffee is the o-ring under the little screen gets dirty and you will know because it will leak on your counter top.
Feb 10, 2011 | Hamilton Beach BrewStation 47214 Coffee...
May 24, 2010 | Water Skeeter Guide Lite Pontoon Boat
Can't pull my starter rope on my Lawn Mower-seems locked up---
If its a Murray lawn mower like mine, it may be using a Briggs and Stratton engine. it sounds like the spring is broken or out of its track You can find the right part which is called a "pulley/spring assembly" by locating the model number of the engine. There are instructions on how to find this at: http://www.briggsandstratton.com/maint_repair/repair_parts/
May 10, 2010 | Garden
My mukka is shooting steam out of the small valve/washer thing on the bottom pot part. As it gets hots the valve pops up (but not with gusto like it used to do) and then I get a little coffee mixed in...
Sep 16, 2009 | Bialetti Mukka Express
Hoover Steam Vac Dual Tank Bottom Valve Spring Assembly Part Needed
It appears that there is a problem with the o-ring design. The o-ring should maintain a certain OD dimension and keep the spring assembly from pulling throught the hole. I am trying to find the service manual to locate the o-ring part number but have had little luck so far. I think that hoover should have maybe used a higher derometer material.
Aug 07, 2008 | Hoover F7431-900 SteamVac Vacuum
Pump not pumping
It's not a one way valve, it's a water strainer. It has a barrel with a fitting on each end, the upper leads into the barrel, the lower has a strainer tube attached. When it's plugging up, it seems like a one-way valve because when you try to force water into the top, it pushes the lint and junk against the strainer screen, blocking it. When you try to force water in from the bottom, the water pushes the lint away from the screen, allowing a reduced flow. Some have an arrow; it's to indicate flow direction to keep the lint on the outside of the screen; the inside, being mush smaller than the barrel, would plug up much sooner. Before you replace the strainer, clean the lint & stuff out of the small pump reservoir (above the pump). If you don't, the strainer will plug up quickly again, if it can even get water to it.
Jul 02, 2008 | DeLonghi DE500P Dehumidifier
WIll not brew
Keurig has a customer service center that you can call. The technicians there will help you with almost any problem you have. That number is 1-866-901-2739. Most problems are caused by blockage in the needles. You have to clean both the one in the k-cup holder and the top lid area. A tooth pick works great for that. Good luck.
Nov 13, 2007 | Keurig Elite B40 Coffee Maker
Water Skeeter Guide Lite Pontoon Boat Logo
891 people viewed this question
Top Water Skeeter Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Water Skeeter Boating Expert? Answer questions, earn points and help others
