Question about Lands Phones
I have an Enzer Eurosat 1000 duo. I can't make or receive calls- the ?antenna sign in the top left corner has disappeared so even though the call button seems to work, I can't connect.
  • 38 Answers
SOURCE: Menu button on top left corner doesn't work, wat can i do?
I wont say try to force it but blow inside hard. To see if anything is in their.
Posted on Dec 21, 2007
SOURCE: Audiosonic TV - Word "Factory" appears on top left corner
Try pressing the RETURN button (above the DISP button - number 6 on the button list in the manual). The button has two arrows chasing each other. It worked for me on our Audiosonic KMC TH68 TV.
Posted on Jun 19, 2008
SOURCE: 3G Symbol
According to the manual this symbol means "HSDPA network connected"
Posted on Sep 30, 2008
SOURCE: sony rm 932 tv cant remove av sign off top left of tv
Hello. I also had this problem and the solution is very simple.
Haha, just press the i+/? button somewhere on your remote.
I hope this fixed your problem!
Greetings, Sven
Posted on Jul 26, 2009
SOURCE: I have telefunken tv, TTV-293D,
DEGOUS THE SCREEN PROBLEM SOLVED.
Posted on Jan 15, 2011
My application iphoto disappeared and says is cache
yes. you might want to try to while you have your safari browser open go to top left corner click on safari and scroll down to empty cache. clears all your current cache.
Mar 16, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Grease under the Coil of a Wilson 1000 CB antenna
Animal greases and Metal grease will conduct electricity. I use silicone grease for my receiving antennas.
Nov 24, 2013 | Wilson Antenna Wilson 880-900802B W-1000...
M1 and m2 are in top left corner. How to undo it?
Press 0 [STO] 1 to clear the Memory M1. Indicator M1 will disappear.
Press 0 [STO] 2 to clear the Memory M2. Indicator M2 will disappear.
Dec 15, 2009 | Texas Instruments TI-30XA Calculator
Sony Bravia 40inch how do I remove input icon
Press " i " (info) button on TV remote and on-screen display will disappear.
Jan 26, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
My Garmin Nuvi 360 we bought approx 1.5 to 2 yrs ago is now having trouble all the sudden finding satelite reception. We just had a major storm come thru our area and it seems to have happened just since...
There are a few things you can try to restore satellite reception.
1. place your finger over the lower left-hand corner of the screen and hold it there
while pressing the on/off power button. Keep holding your finger there and a window
should pop up asking if you want to go into maintenance mode. Select yes. There is an
option called "clear user data". Select that option. It will not erase your favorites.
It will however, erase any corrupted satellite data and will default you back to some
factory settings. This will clear some of the memory allowing your Nuvi to collect new
satellite data. Your Nuvi should reboot and it will ask you a couple questions like,
timezone, language. Please select the proper settings.
Make sure the antenna is up and that you are outside. On the main screen, you will see a
satellite bar graph in the upper left-hand corner. Touch the bar graph and you should
get a satellite map, showing the satellites. If your Nuvi's receiver is working ok, you
should see horizontal hollow bar graphs appear on the right. Eventually they will turn
solid blue. This indicates they have downloaded the proper data from the satellite. When
you have (4) solid blue horizontal bars (4 satellites), you will see the top panel begin
to show improved accuracy and your Nuvi will then work as it should. This entire process
make take 30 minutes or less.
If you don't see any bar graphs, your Nuvi may ask you several minutes later, if you are
indoors. If your outside, select no. It will then ask you if you have moved 1000 miles
since your last use. Select yes. This will cause your Nuvi to start looking for
satellites, trying to locate your new position. When you perform a factory reboot, your Nuvi thinks it's in Kansas (Garmin HQ) and so it needs to be told to look for new satellites.
Now, if you still don't see any bar graphs, then your antenna may have a problem. There
is a known issue with the Nuvi antenna where a part has failed, causing the Nuvi to no
longer use its internal antenna and it's now always looking for an antenna at the
external antenna port (the gold connector on the side of the Nuvi antenna). If you have a
piece of small wire, a couple feet long, you can insert that into the center lead of the
external antenna jack. Most likely, you'll begin to see bar graphs after a few minutes
and your Nuvi will lock.
I haven't been able to identify yet, which part has failed. I am working on that.
However, if the piece of wire works, you can always go on eBay or a retail store and
purchase an external antenna for your Nuvi. They are magnetic and can either stick to
your roof or any metal surface within your vehicle.
Here's another way to determine if your antenna has failed and will have to be replaced:
At the main menu, pres on the "wrench" symbol. Then press the "gear" symbol and then
press "about". There is a field marked "GPS S/W". There should be a number next to it.
It may be "2.9" or "3.0". That is good. That tells you that the main board in the GPS
is communcating with the antenna receiver. If you see "0.0" then your antenna is
defective and there's no way to repair it other than replace it.
Please let me know if I can be of further assistance to you.
- Jim
Oct 08, 2008 | GPS
Handsfree sign top left of phone
hi,
try to clean the bottom part of your phone..
where the charging pin is located.
try to clean the part where you plug your headsets..
Aug 19, 2008 | Sony Ericsson K610i Cellular Phone
Headset sign
(Plz.read fully)
Hai friends,let me first inform u that how your nokia 6630 detects it's headset.
There are 13 connector pins at the boottom of yr cellphone.4 for usb connectivity,others for headset,mic,switch,antenna(not in order).
The first pin from left(plz. neglect the isolated pin near to the edge) is ground
(-ve) and the second one act as a sensor for detecting headset is connected.
When the normal headset jack is plugged in, it short circuits the ground pin
Aug 12, 2008 | Nokia 6630 Cellular Phone
Lands Phones Logo
62 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
