Question about HP Pavilion dv6000z Notebook
When I closed the laptop with a card laying on the keyboard, the pressure popped off 4 of the function key tops. Each has two white plastic "skeletons" under the key. Those have separated from the laptop as well. How can I repair those 4 keys?
  • 242 Answers
You should be able to clip the "skeletons" back onto the keys, however if the clips are broken you can purchase new keyboards from here. Instructions for trying to put the keys back together can be found here and instructions for replacing the keyboard can be found here. Steps 5-8 cover keyboard removal and just reverse them for install.
Hope this helps
Ray
Posted on Mar 16, 2011
Oi.
White macbook 10.5.8 pop spilled on keyboard
Ooouch ! After you've dabbed up (the spill) as much as you can, you may find some keys sticking ... i.e. when you touch (push) it (down), it doesn't pop up immediately. These are the keys you'll want to clean individually.
You can pop off the key top off (with your fingernails) from the top corner of the key. Once the key-cap top (cover) is pried open, lift the key-cap upwards and detach it from the bottom edge. You'll hear pop's when you do this. Once the key-cap is off, you'll see the mechanism under it. You'll want to clean things as best as you can ... very carefully. If the underside of the key top (cap) is sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it). Often the "stickiness" is caused by the (white translucent) plastic pieces (at the very top) not dropping flat down (immediately) after you lift it. (You wouldn't want to disassemble the parts below the (white translucent) square plastic pieces. Just clean/wipe it carefully using a cotton swab/toothpick).
You can remove the top (square plastic) pieces by pushing the tabs at the bottom corners ... downwards ... using a toothpick. This "top" square piece is actually two (square) pieces (snapped together), one inside the other. The inside piece is supposed to spin easily/quickly .... if not. it's probably sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it).
The trick is to make sure you know/remember how to reassemble the 2 pieces (after taking it apart and washing/rinsing/drying it) applying the right connection points to fit ... before you put the key-cap back on . The key-cap is put in place by just putting it in place and pressing down to snap it back on.
The larger keys (Shift, Space, etc.) has metal bars holding down the cap, etc., so it may take more effort to pop the key top (cap) off.
If you have quite a few to do, and you don't want to risk breaking anything, the Apple store is probably your next stop.
Oct 26, 2013 | Computers & Internet
Key has popped out of laptop
The underparts of a key is very fiddly.
1) Its a two part plastic clip that connect together in a cross shape.
That will fold flat (think of a deck chair)
Part one will have small plastic prongs either side
Part two will have a recess hole for part one prongs to slot into.
They must be put together the right way up
2) These two connected plastic clips at each end also have a notch.
You have to hook the plastic clip notch under metal holders that are on the keyboard base.
3) Plastic clips will then lay flat which you just push down (snapin) the key.
Hard to explain - google a video.
Aug 11, 2012 | Computers & Internet
How do I remove the hard drive from a HP XH485 Pavilion Notebook
I think the HDD is under the keyboard on that model (doh!), which is probably why you're asking. If you can't find it under any of the access panels on the bottom, you're in for a bit more work...
1: Close the laptop and view it from the rear where all of the ports are. There are 2 hinges for the screen. Remove the 2 screws that are in those hinges. They are only holding a plastic cover in place.
2: With the screws removed, open the laptop and open completely, so the laptop is laying flat open. At the top of the keyboard is the button panel and removes fairly easily. Use a small and thin flat tip screwdriver to carefully lift up this panel. I started from the right side as it is easier to pop off. The left side is a little more stiff. Once you get most of the right side up, gently pull to the right and wiggle carefully top pull the panel completely off.
3: The set screws for the keyboard are now exposed. There are 4 of them. Remove them and you should easily be able to lift the top of the keyboard and fold it gently towards the front. Do not pull or disconnect the keyboard.
4: The Hard Drive should be completely visible now. There are 4 screws holding the caddy down. Loosen these screws completely. They should not come out. After the screws are loose, pull on the strap at the front of the caddy. Pull straight up firmly and carefully. You may want to jiggle it slightly to work it up, and be prepared for it to pop out on you. It can be in there pretty stiff, and you don't want to damage any thing.
5: If you need to, remove the drive from the caddy, take the connector on the drive pins off first, and then remove the 4 screws attaching the caddy to the HDD.
Closing it up should follow smoothly in reverse order.
Nov 09, 2011 | HP Pavilion xh485 Notebook
Replace keyboard on acer 8100 series laptop
Replace the inside of the keyboard with a new piece. One of the major problems with Dell keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Papatek.com or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
http://www.papatek.com/Acer-Keyboard/Acer-Travelmate-8100-keyboard.html
Jul 23, 2010 | Acer Ferrari 4000 Notebook
REPLACING KEYBOARD OF A ACER 3002 LCI LAPTOP
Replace the inside of the keyboard with a new piece. One of the major problems with Acer keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Papatek.com or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
Jul 01, 2010 | Acer Aspire 3002LCi Notebook
PUED IN AN AUXILLIARY KEYBOAD NOW THE LAPTOP
Replace the inside of the keyboard with a new piece. You can find a cheap keyboard from Papatek.com or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
Apr 20, 2010 | Acer NSK8458AN Keyboard
Popped a key off my Dell Inspiron laptop keyboard by accident.
You should be able to just pop off another key from your keyboard using a flat screwdriver. Then just compare how that key looks and reassemble the plastic components and the key just snaps back on. Also you may want to check your warranty at support.dell.com under warranty status and enter your service tag. If you are under warranty dell will replace it. Also ebay dell keyboards are cheap to buy and easy to install just two screws and a simple cable. If you need more help let me know.
Nov 30, 2009 | Dell Inspiron 6400 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Loose key hp dv6000
if the plastic scissor is broken or the end clips are broken you will have to replace it LINK
hp uses 4 or 5 different type of plastic key holder so if you need one be sure you order the right one
May 08, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
