Question about Sony Computers & Internet
I forgot my BIOS password on my Sony VGN A790, I haven't used it in awhile. I can't get in. Any answers?
  • petereal30 Mar 16, 2011
    Taking out the cmos battery did not fix it. Only having a master password will work
  • 22 Answers
Nope!!!
Posted on Mar 16, 2011
  • 1 more comment
  • Sahil Uppal Mar 16, 2011
    You entered a password into the BIOS setup program to control access to the system, and then forgot the password. If this a setup password, you will be unable to enter the BIOS setup program. If this is a startup or boot password, you will be unable to boot the system at all.
    For most people, using the BIOS passwords isn't a great idea, and this is the main reason why. If you do use a password, you should always record it in writing somewhere in case you need it later on. It can be hard to get around this sort of a problem, precisely because if there were an easy way to get around the password, it would have no value. In most cases you will have to clear the CMOS memory to erase the password.
    Recommendation:
    If you haven't already, and if you can live without the machine for a day or so, wait and try to remember the password. This is the best solution, if you can remember it. :^)
    If your system has an AMI BIOS, try the default password, which is either "AMI" or "ami". This will not usually work, but is worth a try.
    If you cannot get into the BIOS program, your only remaining option is to try to clear the CMOS memory that holds BIOS settings. Included in this memory is the password, so this will let you get back into the PC. See here for instructions on erasing the CMOS memory.
    If it is a setup password that you are trying to get around, then you can at least boot the PC. It is possible in some systems that performing a flash BIOS upgrade will clear the CMOS memory and eliminate the password. I would not recommend trying this without getting confirmation from your motherboard vendor first, as doing flash BIOS upgrades in strange situations can theoretically be dangerous.
    This is how you reset the CMOS
    Turn off the PC. Hold down the {Insert} key and then turn the PC on and wait for it to boot. On some PCs, this will clear and reset the CMOS memory for you. (On most PCs it will not work, so don't be discouraged.)
    Try the same thing with the {Delete} key. Again, it usually won't work.
    Look in your motherboard or system documentation for any evidence of a CMOS clear jumper. This is a jumper on the motherboard that can be used to clear the CMOS memory; many newer motherboards have them. Follow the instructions for its use as described in the documentation; usually this means opening the PC, changing the jumper to a special setting, and then booting the PC. The CMOS memory will be cleared. Then you power the PC down and put the jumper back to its previous position. If it doesn't work properly when you try it, look here.
    If you do not have a CMOS clear jumper, your next option is to try disconnecting the CMOS battery. This is easy to do if the battery on the motherboard is removable or user-replaceable. If you see on the motherboard what looks like a flat round wristwatch or calculator battery in a holder, that's it. Some older motherboards use batteries that sit off the motherboard and connect with a wire. If the battery can be disconnected, then disconnect or remove it. Wait for about two hours (you may need to vary the amount of time; if two hours isn't enough, try leaving it overnight) and then plug it back in, and the CMOS should be cleared and reset.
    On some systems, the CMOS battery is integrated within the BIOS chip. You may have success with removing the chip for a few minutes and then replacing it. Just be very careful to take anti-static precautions.
    Your motherboard may have a battery that is soldered to the motherboard. You may not see a battery on the motherboard at all; if this is the case then your motherboard probably uses a battery that is integrated into the real-time clock chip (or else, you weren't looking closely enough :^) ). Unfortunately, on a motherboard without a removable battery and with no CMOS clear jumper, clearing the CMOS memory is difficult to do. At this point you should contact your manufacturer for technical support.
    can you tell us what's the serial number of you computer. May be we can arrange that for you as it can be generated through serial number only.
Forgot bios for sony vgn-SR19XN
Bios passwords on laptops are only over rode by the the manufacture. This is because they are easy theft items. IBM for instance have a government contract so they will never offer you support for that. You can prove ownership to Sony they may have a master password. Good luck though not heard any company yet that will give that info over the phone. There is NO work around for a that other than Sony doing it.
Mar 23, 2014 | Sony Vaio PCG-7F1L PCG-8A1R PCG-8C3L...
I forgot my sony vaio bios password
Remove the battery, remove the power cord and start taking the laptop apart. You will need to remove the CMOS battery located on the motherboard and let it sit for an hour or two. Then but it all back together. The CMOS battery is a silver battery about the size of a nickel.
Mar 24, 2012 | Sony Vaio P VGN-P530H Netbook
I have bought a sony vgn-n38e anf i am not able to scroll up or down on the right hand side of the touch pad, i would like to know if there is simply a button to press to rectify this or if it is possibly...
So you need to update driver for this touchpad scrolling error.
Please click on the below link
ftp://download.sony.com/US/pc/ALDOTH-00199336-US.EXE
This will download the driver for your touch pad then you need to run the driver that you downloaded.
Then restart the notebook
Check whether it is working.
you can find other drivers for Sony Vaio VGN-A790 on the below link.
http://www.notebook-driver.com/sony-vaio/sony-vaio-vgn-a790-notebook-windows-xp-drivers/
Hope this resolve your query.
Kindly provide your valuable feedback for this answer
Thanks.
Nov 11, 2010 | Sony VAIO VGN-A790 Notebook
Sony ,VGN-AR605E onetime password
Remove the CMOS battery and replace it after 5 minutes. It will reset your bios to default configuration. :)e421fa4.jpg
thanks to electronic clinic for the image
Mar 09, 2010 | Computers & Internet
I can't find the second memery slot on sony vaio vgn a790
Second memory slot is under the keyboard. If you use link below and select 'user guide', then go to page 148 and it gives you detailed instructions on how to access the second memory.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=VGNA790
I would appreciate feedback if this is useful. Thanks
Jan 28, 2009 | Sony VAIO VGN-A790 Notebook
Blank (dark) notebook screen after hooking up digital ext monitor
I notice a difference in the setup of the two monitors, have you installed the correct driver for the new screen?
Try F8 on startup to get into safe mode, this should allow you to use the default VGA screen, and to reset the correct monitor drivers.
Dec 08, 2008 | Sony VAIO VGN-A790 Notebook
Sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
Oct 11, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
