Question about Healthometer Health o meter Body Fat Fitness Bfm884dq 60 (Health O Meter)
I have a BFM790DQ-60 A301BN. I don't know the numbers that briefly flash up. I know some are fat percent, hydration and tracking of previous weight. In what order do they come up? Is bone weight also calculated? You may not have this exact model but pleas give some ideas of the values that appear. Maybe I can then figure them out. Thanks
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
Is there an 800 number to call?
Health o Meter Brand Customer Service
1-800-672-5625
Jun 02, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
I have a healthometer BFM920KD-01 scale and
Just push either the #"1" or "2" user button and hold it down. The display will flash the height numbers. Hit the Up or Down arrow to change the flashing "5" to a six, etc. Then hit the "set" button to "enter" your choice. This advances the display so that you can now change the inches, gender and age. You're good to go!
Apr 14, 2012 | Health-O-Meter Health o Meter BFM588DQ-81...
Formula for converting fractions into percentage.
Simplest method
  1. divide the top of the fraction by the bottom
  2. Then multiply the result by 100
  3. add a percent sign to the answer so people know it is a percentage (i.e. per 100)
  • e.g. 3/5 *100 = 0.6 * 100 = 60%
Alternative method Since percent means "per 100", you can try to convert the faction to the form ?/100
follow these steps:
  1. find a number that you can multiple the bottom of the fraction by to get 100
  2. multiple both top and bottom of the fraction by that number
  3. write down just the top number with the % sign added to the end
  • e.g. 3/5 as a percentage
  1. we can multiply 5 x 20 to get 100
  2. multiple top and bottom by 20 = (3*20)/(5*20) = 60/100 = 60%
I hope this helps and good luck! If you have more questions - ask away! Please take the time to rate this answer.
Don.
Sep 08, 2011 | Computers & Internet
How to calculate a percentage - whole numbers
Say you want to know what percent x is of y (or To find out x is what percent of y).
We take x / y and times 100. Depending on what x and y are this might not always be a whole number,
we could round the number off to a whole number. An example: 81 is what percent of 135? To solve this
take (81 / 135) * 100 = (0.6) * 100 = 60 percent.
Mar 29, 2011 | Office Equipment & Supplies
Instead of showing my weight in pounds (168.00), the window is showing a different kind of number (75.). I don't know how that happened. What should I do to correct this.
Your scale is showing you your weight in kilograms what you need to do is change the settings so it shows you your weight in pounds or stones
Sep 19, 2010 | Conair Weight Scale "Thinner" with Body...
Where can I get a manual, after moving I can't find mine!
Troubleshooting Conair WW81 Weight Watchers Body Fat/Hydration ... Solve Your "Conair WW81 Weight Watchers Body Fat/Hydration Scale" Problem Now! ... Tanita Ultimate Scale 2001 - no user manual -how to set. ...
www.fixya.com/support/...conair_ww81...body.../solutions
Oct 05, 2009 | Conair WW81 Weight Watchers Body...
MY bfm588dq-81 scale is malfunctioning. The
Throw it away. The product sucks. I know, I'm throwing one away right now and I"ll NEVER purchase one again.
Aug 17, 2009 | Health-O-Meter Health o Meter BFM588DQ-81...
I need a manual for this scale and can't find it.
you didn't say the brand, but have you tried looking up the manufacturer, I know a lot of times there will be an are on their website where you can request something like that, or even get a phone number for the maker and request one over the phone:) hope that helps you.
Feb 01, 2009 | Conair WW73 Electronic Body Fat/Hydration...
BF% is wrong
Unfortunately, it's the scale, but it's not broken. It simply is telling you inaccurate information.
Some scales utilize Bioelectrical Impedance Analysis (BIA) technology. BIA uses very low levels of electrical impulses running from one metal contact point/lead to another. Your body acts as the connector between the two contact points, thus completing the circuit. Not all scales use this means for calculating body fat percentage due to poor reliability and high fabrication costs.This method of measurement requires very large contact points, as well as clean and moist skin exposure. If you have dry/calluced feet, which is normal for most Americans, the sensors can not accurately measure due to skin resistance. Dry skin acts as a resistor to electrical impulse. Electricity passes through muscle and fat at different rates. However, its measurements may be thrown off by how hydrated you are and how much you've eaten; it may be too inaccurate for anything other than comparative use. Users are encouraged to establish a baseline measurement and repeat measurements under consistent conditions over time to detect changes.
Many less expensive models simply use a body-fat calculator to average your imputed height in inches, waist measurement in inches and the current weight measurement recorded in lbs. The scale compares your measurement with the ideal norms inputed during the manufactoring process, thus giving you a comparison vs.imputed norms. People who are very, very fit can get numbers 3 to 5 percent higher than their true percent body fat. Because they don't have a lot of fat inside their muscles(visceral fat), the simple tape measure calculation test cannot adjust as it should indicate.
Conversely, if a person is skinny but not fit, this body fat test may yield a number 3 to 5 percent lower than his or her true percent body fat. Though they look thin, unfit skinny people really have more than the usual amount of fat inside their muscles, which you can't see from the outside.
In either case, the scale is not necessary a measurement tool, due to high variables of test inaccuracy and interuser reliabilty; but, it is a good tool for comparing whether or not you are gaining/losing body fat.
If you would like a more accurate tool for simply measuring your body fat, you can pick up some pinch-calipers online for about the price of a scale. They come with an instructional pamphlet, very easy to use.
Jan 13, 2009 | Conair Weight Watchers WW-87 Body Fat...
Healthometer Health o meter Body Fat Fitness Bfm884dq 60 (Health O Meter) Logo
432 people viewed this question
Top Healthometer Health & Beauty Experts
StormERage
Level 1 Expert
Tom Chichester
Bill Boyd
Are you a Healthometer Health and Beauty Expert? Answer questions, earn points and help others
