Question about Seagate (ST3160827AS) 160 GB Hard Drive
Not creating partitions - Seagate (ST3160827AS) 160 GB Hard Drive
  • 20 Answers
Please elaborate your issue......
Posted on Mar 16, 2011
How do we create a new hard disk partitions? Please help. Thanks.
Here are two methods to create a new partition:
Method 1: Create partition in Disk Management
Step 1: Open Disk Management. Right-click Start button to find Disk Management. If you get the UAC dialog box, then give confirmation.
Step 2: Right-click on the unallocated space and select New Simple Volume from the context menu.
Step 3: Follow the on-creen gude of New Simple Volume Wizard to computer the task. 2222-l4z23du0euvv25ewe4orlrwr-4-8.png
Method 2: Create partition using free partition manager without data loss
Step 1: Install and launch PartitionGuru Free and locate the disk where you want to create partition.
Step 2: Right click the disk and select "Split Partition". This this split current into 2 partitions without data loss.
Step 3: Decide how much space you would like to move to the new partition, and click "Start" button. You can either enter the exact disk size or drag the arrow between partition bars to set the size.
Oct 18, 2016 | Hard Computers & Internet
How to create c drive in pc?
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Jun 18, 2012 | Intel Computers & Internet
120 gb hdd shows only 3.99gb
Your hard drive maybe partitioned with a small partition and the remainder of the hard drive may not be partitioned at all and therefore not accessable until a new partition has been created and formatted.
You may wish to delete the existion and then create one partition of maximum size.
NOTE - backup your data because when you delete the existing partition and create a new partition and format this partition you will lose your data.
Feb 11, 2012 | Computers & Internet
Pls help me to partition my hard disk drive as c and D
If the computer is already running with Windows, then you can use a program called Partition magic to partition the C drive into two partitions - a C and a D drive.
If you are installing Windows from scratch then you can use the Windows installation CD to install Windows. When the Windows installation begins, delete the existing partition, then create a new partition but size the 1st partition (C drive) to what you require and continue with the installation.
When Windows has finished installing you can create the D drive by opening Control Panel - Administrative Tools - Computer Management - Disk Management - click on the un-partitioned portion of the hard disk, create a extended partition - and then format this partition in NTSF When completed Disk 1 will be shown as Healthy (system)
Mar 20, 2011 | Computers & Internet
My hp touchsmart 300 hard drive went out i got another hard drive but it needs to be formatted and pratitioned but i cant figure out how to do that
  • Start the computer in Command Prompt Mode. Type "FDISK." The partition window will appear with menu options. Enter 5 if you're partitioning a second drive, and select the drive; otherwise, skip to the next step. Enter 1 (Create DOS Partition or Logical DOS Drive). Enter 2 (Create Extended DOS) to create a partition. Enter N when the program asks if you want to use the maximum available size. Designate the amount of disk space to allocate to the second partition (the partition will be assigned the next drive letter) Type a name for the new partition and press Enter. The partition menu will appear. Repeat steps 5 through 8 to create additional partitions. Press Esc to exit the partition command. Format the newly created partitions
  • Jul 28, 2010 | HP Computers & Internet
    How to create a logical drive in windows vista home basic?
    You must be logged on as an administrator to perform these steps.
    To create a partition or volume (the two terms are often used interchangeably) on a hard disk, there must be either unallocated (empty) space on the hard disk or free space within an extended partition on the hard disk.
    If there is no unallocated space, you can create some by shrinking an existing partition, deleting a partition, or by using a third-party partitioning program. For more information, see Can I repartition my hard disk? For more information about reformatting a hard disk, see the "What is reformatting?" section below.
    aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
    Mar 31, 2009 | Microsoft Windows Vista Ultimate Edition
    How to Create EISA Partition...in Vista Or XP......
    You can't. The partition was created by SONY to hold recovery files because so many people lose their installation disks. So SONY created the partition, loaded the special software on it and put options in the menu to use it.
    Jan 23, 2009 | Microsoft Windows Vista Ultimate Edition
    Active directory
    An application directory partition is represented by a domainDNS object with an instanceType attribute value of DS_INSTANCETYPE_IS_NC_HEAD combined with DS_INSTANCETYPE_NC_IS_WRITEABLE. This domainDNS object represents the application directory partition root (NC head), and is named similar to a regular domain partition, for example, "DC=dynamicdata,DC=fabrikam,DC=com", which corresponds to a DNS name of "dynamicdata.fabrikam.com". An application directory partition can, therefore, be instantiated anywhere a domain partition can be instantiated. There is no NetBIOS name associated with an application directory partition.
    It is possible to nest application directory partitions, that is, an application directory partition can have child application directory partitions. Searches with subtree scope rooted at an application directory partition head will generate continuation references to the child application directory partitions.
    An application directory partition replica can only be created on a domain controller that is running on Windows Server 2003 and later and only while the Domain-Naming FSMO role is held by a Windows Server 2003 and later domain controller. In a mixed forest that has both Windows Server 2003 domain controllers and down-level domain controllers (Windows 2000 domain controllers or Windows NT 4.0 primary domain controllers), an attempt to create an application directory partition replica on a down-level domain controller will fail.
    An application directory partition also has a corresponding crossRef object in the Partitions container of the configuration partition. The crossRef can be pre-created manually before creating the domainDNS object. The pre-created crossRef object must have the attribute values shown in the following table or the partition creation will fail. If the crossRef object does not exist, the Active Directory server will create one when the application directory partition is created.
    Jul 09, 2008 | Microsoft Windows Server Standard 2003 for...
    Partition
    hi there,
    the first partition is always the healing partition so u can use the other healing partition for your files/docs.
    Apr 10, 2008 | Dell Inspiron 6400 Notebook
    Seagate (ST3160827AS) 160 GB Hard Drive Logo
    Top Seagate Computers & Internet Experts
    Arora Singh
    Arora Singh
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
