Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Heater set-up is ok with water flow confirmed the heater will try to light up (can hear clicking sound) then a significant flame will come from the heater forcing the front cover off. Have not started since but before calling a gas service man any ideas. The are at the bottom of the heater has been exposed to water and wondering if this could be an issue.
    President:
  • Jandy Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
The jets nearest to the ignitor are clogged causing a large ignition flame roll-out. You can try to fix this by unthreading them from the manifold and cleaning out all the orifices. Once done your unit should return to lighting normally.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Mar 16, 2011
Any idea why my Atwood water heater will shut the main burner and the pilot light off at the same time? Sometimes runs for 20 minutes, sometimes 2. I hear a clicking sound, then they both shut off.
The thermostat shuts off the main burner.The pilot light gas is controlled by the thermocouple which the side of the pilot flame has to envelop. If the flame is too small or too far away from the flame, it shuts the gas off to the pilot. The thermocouple generates a small voltage which keeps the pilot gas open. It can over time fail itself, so look at replacing it. The thermostat sounds like it's failing too.
Apr 27, 2016 | Water Water Heaters
The flame in my noritz tankless water heater turns off when I lower the pressure of water flowing from the faucet (however when the flow of water was at high pressure the flame never turned off). This also...
has this heater always acted like this? if so
you need to supply heater with the right water pressure or flow
try cutting back by turning inlet valve off to restrict flow or restrict flow on hot end. hope it works it did on mine
Dec 30, 2014 | Water Heaters
Hey all I have a raypak pc131pc0 gas spa heater. Having a slight problem with ignition got it second hand and trying to get her going. I can get ignition and after about 5 seconds I hear a click and she...
if wired 120 volt look on the inside front cover you have to change wires sometimes the ignitor to 120 volts on the fenwall or the ignitor will not get hot enough if wiring is ok reverse black and white wires and try
Sep 05, 2014 | Pool & Spa
check wiring diagram on inside of front cover if hooked up 120 volt try switching the black and white wires it sounds like its not showing rectification also if 120 volt wires have to be changed sometimes you have to change the ignitor to 120 volt pin
Outlet water gets so hot it ballooned the PVC pipe like an anuresum. Lights and shuts down, assuming that is a limit switch working properly. Filters cleaned last month/water pressure seems adequate.
Your thermopile that tells the heater how hot the water is has failed. It should kill the heat at a temperature of 104f. This also indicates that the limits are not doing their job, as they should be killing the heat at 135f (low limit) or 150f (high limit). Schedule 40 pvc is rated at about 140f.
This many failures at once is rare, and typically indicates that the heater has been rigged. Get a tech out to fix it correctly. You are literally playing with fire.
Nov 28, 2013 | Hayward H Series Pool & Spa Heater 400k...
No hot water no flame gwh1600h bosch
Tell me more! --
Do you have any other gas appliances in the house?-- and they are firing OK? Can you hear the gas flowing when you push in on the ignition start button? -- There should be a spark as you 'snap' the button?
Remember-- YOu get no ignition of the big flame, until you have water flowing--
How old is the heater?-- Could there be come obstruction in the water flow sensing device?
Oct 13, 2013 | Water Heaters
Bosch aquastar Aq125-hx does not produce hot water. Pilot is ok. Gas and Flame heat is ok. water pressure is ok. Just no hot water getting to the faucets. Help.
That particular tankless water heater has hydro-generated ignition. In order for it to function, it requires a certain water pressure and velocity. You can try turning on the hot water in two location in your house to see if that gets it started. If it does, try getting a higher flow shower head, or removing the limiters in your faucets.
Jan 07, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Pilot light will not automatically light when hot water is turned on
This is a great unit! Try turning the flow nob to the half way point and the flame all the way to low. Run the hot water tap and slowly turn the flame dial until you hear the unit try to light. Every house is different regarding the restrictions in the plumbing and water pressure. Once the unit tries to light that is your minimum setting. It is best to leave it there.
Apr 05, 2010 | Bosch & Tankless LP Hot Water Heater
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
62 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
