Question about KiasWorld Chat
Standard valve tappet clearance on kia pregio
Hey there I need the exhaust and Intake(valve) clearance for a komatsu 300-6 please
note Perform the valve clearance check and adjustment at the engine cold state. 1.Remove all of the ignition coils. 2.Remove the cylinder head cover.
caution Turn the crankshaft always clockwise. 3.Turn the crankshaft clockwise, and align the timing mark on the exhaust camshaft sprocket against the upper face of the cylinder head as shown in Figure. Therefore, No.1 cylinder goes to the compression top dead center. 4.Using a thickness gauge, measure the valve clearance with the arrow shown in Figure. If deviated from the standard value, make note for the valve clearance.
Standard value:
    Intake valve 0.20 ± 0.03 mm (0.008 ± 0.0012 inch)
    Exhaust valve 0.30 ± 0.03 mm (0.012 ± 0.0012 inch)
5.Turn the crankshaft clockwise 360 degrees, and put the timing mark on the exhaust camshaft sprocket in position shown in Figure. Therefore, No. 4 cylinder goes to the compression top dead center. 6.Check the valve clearance with the arrow shown in Figure. In the same procedure as 4.
7.If the valve clearance is deviated from the standard value, remove the camshaft and the valve tappet. For the camshaft removal, refer to Camshaft Removal and Installation . 8.Using a micrometer, measure the thickness of the removed valve tappet. 9.Calculate the thickness of the newly installed valve tappet through the following equation.
A: thickness of newly installed valve tappet
B: thickness of removed valve tappet
C: measured valve clearance
Equation
    Intake valve: A = B + [C - 0.20 mm (0.008 inch)]
    Exhaust valve: A = B + [C - 0.30 mm (0.012 inch)] note The valve tappet ranges 3,000 - 3,690 mm (0.1181 - 0.1453 inch) and has 47 types per 0.015 mm (0.0006 inch). The thickness below a decimal point is stamped on the reverse side of the valve tappet. 10.Install the valve tappet selected through the procedure 9, and put the camshaft in position. For the camshaft installation, refer to Camshaft Removal and Installation .
    11.After installing the timing chain, measure the valve clearance using the procedure 3 to 6. Confirm the clearance is within the standard value.
    caution Completely remove all the old FIPG, which might be remaining among the components. 12.After completely removing the liquid gasket adhering on the timing chain case, cylinder block and cylinder head, degrease them with white gasoline.
    caution The cylinder head cover should be installed within 3 minutes of applying liquid gasket.
13.Apply a 4 mm bead of liquid gasket as illustrated.
Specified sealant:
    THREE BOND 1217G or equivalent
14. Install the cylinder head cover and tighten the tightening bolts using the following procedures.
(1) Temporarily tighten to the following torque in order shown in the illustration.
Tightening torque: 3.0 ± 1.0 N·m (27 ± 8 in-lb)(2) Tighten to the specified torque in order shown in the illustration.
Specified torque: 5.5 ± 0.5 N·m (49 ± 4 in-lb)15.Install the ignition coils.
Jan 23, 2017 | Cars & Trucks
How do I fix the tapping sound from the engine when i accelerate after it has reached running temperature
Adjust the valve tappets (yes, they 'tap') AKA Rockers or find out why the hydraulic self adjusting tappets don't work?
They transfer the downward motion of the cams on the camshaft to depress the valves. There is a thin clearance of about 8 thousandths of an inch with the engine cold. As the engine heats the clearance reduces. Over tightening causes the valve edges to burn, too much clearance causes tapping.
Manual tappets get quieter usually as the engine heats. Hydraulic tappets gets worse as the engine heats as the oil thins.
Oct 03, 2015 | Cars & Trucks
Can you adjust valve clearance on kia optima 2.0 cdti
Depends on the year and engine. The older engines have hydrolic lifters. The newer engines 06 and up with CVVT have solid lifters so you would have to pull the valve covers and use a feeler gauge to measure clearances and replace the tappets accordingly.
Nov 06, 2013 | 2006 Kia Amanti
Adjustment clearance valve rocker tappet
Pulsar 135 original tappet clearances
INTAKE VALVE 0.05 mm
EXHAUST Valve 0.10 mm
Get this valve adjustment done by the experienced mechanic with the help of Feeler Gauge
Aug 28, 2013 | 2010 Bajaj Pulsar 135 DTSi
Valve clearances kia pregio
the valves are hydraulically adjusted so any noise you hear will be worn rocker shafts or rocker bushes.
Jul 20, 2013 | Measuring Tools & Sensors
Valve clearence settings mazda protege 2003
This is for a non turbo2_24_2012_5_45_49_am.gifNew adjustment shim =Removed shim thickness+ measured valve clearance- STANDARD VALVE CLEARANCE (0.26 mm or 0.010 inch)
Feb 24, 2012 | Mazda Protege Cars & Trucks
How to measure tappet clearance with dial gauge
When setting tappets, it has to be born inind that the valve stem wears an indentation into the face of the rocker. This prevents a really accurate tappet adjustment, so the customer is right again. If you do not posess a tappet setting dial gauge, a normal engineers dial gauge will do just as well. The procedure is the same as using your feeler gauge except that you set the dial gauge up on the cylinder head with the pointer resting on the head of the rocker. Press down fairly firmly on the rocker valve end and zero the gauge. Next lift up on the rocker and read off the clearance, from the gauge, Use a magnetic base to support your gauge and repeat the pocedure for each valve pair.
Mar 25, 2010 | 1988 Mitsubishi Cargo
Tappet Clearance
This is not a forum for automotive data. But "tappet clearance" is a UK term, only. Try search for "valve clearance" and "Hilux 2400 cc" or Hilux 2400cc"
Feb 08, 2008 | Computers & Internet
Facebook Apps Logo
247 people viewed this question
Top KiasWorld Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a KiasWorld Facebook App Expert? Answer questions, earn points and help others
