Question about AndrosaSoft Androsa FileProtector
Installed androsasoft but after secreting the files cant open them it comes out : Registry error: Error! Install directory not found! This can cause some errors during the operation! Reinstall the software to solve. Reinstalled many times but always same problem. I'm using windows 7. Thanks. regards Joe
  • Jon Harrison May 25, 2013
    i am having same problem, let me know if you got this fixed
I found vga drivers but it not work either i installed directly from the icon or from root directory of the this model d530 cmt. how can i install vga drivers?
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reginout registry cleaner and then install ur recommended driver as u want to install vga driver.
Aug 31, 2010 | HP Compaq d530 CMT PC Desktop
Error 2123 appears when loading rosetta stone
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
Feb 20, 2010 | Rosetta Stone Japanese Level 1 & 2 for...
I can't open my windows xp in virtual box because of these errors VD: error VERR_PATH_NOT_FOUND opening image file 'C:PROGRA-1Sun|Virtual-1VBoxGuestAdditions.iso'(VERR_PATH_NOT_FOUND). Failed to open image...
try reinstalling it and if that doesnt work i maybe able to help you if reinstalling doesnt work, because it maybe that it didnt install all the files or some are corrupt or it could be the location you installed it to
Feb 17, 2010 | Computers & Internet
I recently installed Bridge Baron 15 on a new laptop with Windows Vista and get the following upon startup 'Error reading Std Am with Strong Two Bids profile!' Any suggestions? I can't get beyond this to...
If You run this program using another account than that, which was used to install it on 64bit windows, your account registry is missing "Program Directory" setting:
[HKEY_CURRENT_USER\Software\Great Game Products\Bridge Baron 15\Settings] "Program Directory"="C:\\Program Files (x86)\\Great Game Products\\Bridge Baron 15\\"
In that case program defaults to search hard coded c:\Program Files\ (instead of c:\Program Files (x86)\ directory)
Dec 19, 2009 | Victory Technology Bridge Baron 15 for...
I have un-installed the printer. I tried to
Reinstall the software into another directory from its default directory.
Program installation are being copied its default folder directly and in your situation just put it another directory or destination of the file.
Another thing is remove a file existed in Registry by using a a Registry Cleaner/Remover.
http://download.cnet.com/1770-20_4-0.html?query=registry+cleaner&tag=srch%3Ba&searchtype=downloads&filterName=platform%3DWindows&filter=platform%3DWindows
Select one of them.
If i am helpful to you please rate me.
Thank you.
Yboyandrei
Aug 23, 2009 | Office Equipment & Supplies
Clue finders math adventures says cannot creat directory
I found the answer to this problem. The problem is the install tries to write to files in the c:\Documents and Settings\All Users\Documents directory. For some reason, that directory had lost the ownership. Try searching for "my documents access denied". For XP home, I had to boot in safe mode, then take ownership of the directory. Once I did this, the install could write to the directory and it installed!
Apr 21, 2009 | Learning Company, Inc. Clue Finders Math...
Cannot install omnipage se. wizard interupts process
When unistalled the previous Omnipage SE 4.0 and try to install new update vresion, an error message keep poping up saying a previous version of Omnipage is still installed in the computer and can not install the new version. No more trace is found for old version in Add/Remove screen. The problems are in the registry area. Just run regedit (export the registry as backup) and look for Scansoft under the software directory. Deleted all the Scansoft omnipage traces then restart the computer will solve the problem.
Nov 04, 2008 | Office Equipment & Supplies
Civilization game help
Hey tycoon211,
If your computer lost power before installation could be completed, some of the files that were being installed may have been damaged or corrupted. Unfortunately, this means that the best solution to peruse may be dictated by the error messages (if any) you are receiving when you attempt to play or uninstall the game.
In many cases, damaged files should be limited to the actual game installation files themselves, but problems have been known to surface in temporary directories, the Windows Install Shield program and even a computer's registry when such problems occur.
As such, the first course of action I would suggest would be to write down any error messages you see when you attempt to play, install or uninstall the game. Once you've done so, you may wish to contact the technical support hotline for the game publisher to see if any diagnostic tools or FAQ's are available for the errors you have encountered.
Next, you may need to manually remove the entire program from your computer in order to reinstall. This can typically done by accessing the "Add/Remove Programs" option found within the Control Panel of most Windows versions, but you may also need to delete any folders left behind in your "Program Files" directory in order to reinstall the game.
If neither of these steps help resolve the problem and you are still unsure how to proceed, I would strongly recommend contacting your local computer repair facility for further assistance. While registry, Install Shield and other errors can often be corrected, you do run the risk of causing further damage to your computer if you attempt to make any changes or corrections with which you are unfamiliar.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 01, 2008 | Video Game Consoles & Games
Soundblaster Live! with Unintall Program with Cd inserted Error Number: 0x80040201 Description: An event was unable to invoke any of the subscribers. Setup will now terminate.
Maybe when you installed it the driver or the program of sound blaster is not finished or have an error. That's why you cannot uninstall it property. goto control panel add and remove software try uninstall the sounblaster. If still not remove completely try this, Click start, run and type msconfig in the startup and service look for sounblaster and uncheck all then try gain to uninstall . If still not working try to delete manually the directory of soublaster and also in the registry. Type regedit in run commmand and click edit,find and find what type soundblaster and click find next. If they found press delete and press F3 to find next directory or files until the search is finished. But be careful to delete only the soundblaster files and directory because if you delete some other files in registry is cause another problem in your systems.
Apr 15, 2008 | Computers & Internet
Error 1304
Apparently some McAfee files are not gone, here lies your problem.
go here to Majorgeeks and download and run the McAfee
remover tool. . Let us know if this fixes your problem
http://www.majorgeeks.com/McAfee_Consumer_Product_Removal_Tool_d5420.html
Nov 08, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
213 people viewed this question
Top AndrosaSoft Computers & Internet Experts
David Payne
David Payne
Are you an AndrosaSoft Computer and Internet Expert? Answer questions, earn points and help others
