Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Just put handle on windtunnel u6401-9rm and the self propelled switch will not flip into self propel mode. is there an adjustment on the self propel part?
  • 240 Answers
When installing the handle on this machine, you must be sure the on/off switch and the self propel button are both in the OFF position. The actual switch inside must also be OFF, and the metal fitting on the end of the power drive cable should be between the two lines molded into the plastic. After it is re-assembled, it is sometimes necessary to wiggle the handle up and down a bit to engage or disengage the drive button.
Posted on Mar 18, 2011
Why won't hoover wind tunnel self-propel?
Hi there! The self-propelled feature is controlled by a belt. Check the belts on your Hoover Windtunnel by following these quick steps.
1. Recline the handle. Lay the cleaner fat and flip it over to expose nozzle base.
2. Remove the screws attaching the nozzle.
3. Check that the belts are not broken, stretched or damaged.
Replace the belts if they are damaged. Hope this helps!
Jul 04, 2014 | Hoover Vacuums
Just replaced the belts on my Hoover Windtunnel II self-propelled vacuum. The brushes are now turning ok, but the self propelled feature is not working. Squeals when when you lock it in the upright...
Check the plastic part, which the the self propelled cable is attached to. (release the handle, tilt it back. You should be able to see the cable attached by a screw to a black plastic arm.) It is either broken or the cable is lose.
Nov 14, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Self-propel switch arm broke off where control cable was attached. Looking for instructions as to how to gain access to that switch arm to replace it.
Greetings from GoVacuum,
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum cleaner.
We have also put together a very helpful video for your vacuum cleaner on how to replace the belts. The belts on this model are also a frequent issue we see with these self-propelled Winddtunnels. In fact, for best results you should change the belts once a year, even if they are not broken, because they do heat up and stretch to a point where they don't work as well as a new belt would. The video also explains how you can maintain the roller brush will help you get the longest life possible out of your belts.
Video Repair on How To Replace The Belts Hoover Windtunnel Self-Propelled;
I hope that this information was helpful to you in repairing your Hoover. If you did find this helpful, may you please rate the repair by clicking the the Thumbs Up Icons in the top right hand corner of this repair to help me start out here on Fixya? I really do appreciate it, thank you so much!
Feel free to request a repair clarification if you have any questions or concerns you'd like to address.
Chris J.
GoVacuum
Feb 22, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Self-propelled WindTunnel U6436-900 cable
the belt could be broken. check the belt for the drive system.
Feb 24, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Self-Propelled WindTunnel U6436-900 cable problem
The flat belt should be changed if it has been longer than 9-12 months. Next I would remove the upper handle to inspect the top section of the control cable, sometimes it fray's and has a sponge feel (no positive control) to self propel. To set this adjustment, it is best to do withthe hood off of the lower section. I would also look at the cable jacket in the foot to make sure it is under the metal clamp. It must be under the clamp to work properly. To get it under the clamp loosen one hold down screw at the top and one in the back of the vacuum, remove clamp screws and put jacket into position and then secure all screws. Now set the adjustment, Install upper handle and set self propel to off. loosen cable from arm in foot with torx screw. manually move arm until the clutch is off both drive pads. This is a visual adjustment. then secure and reassemble vacuum.
Feb 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Self Propel doesn't work! where does the cable attach from handle? How do u do it?
if you haven't already gotten this fixed, simply remove the two screws on the bottom of the handle. Inside is the cable; please make sure to unplug your vaccum first.
Sep 05, 2006 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
183 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
