Question about Compaq Presario M2000 Notebook
Compaq Presario C300 Screen Hinges
I am trying to replace the screen hinges for my laptop but am struggling o take off the laptop screen cover?
Any help would be greatly appreciated!
  • LukeHa Aug 01, 2008
    Are these the rubber caps on the screen surround? There are 4 in eahc corner and two at the top of the screen in the middle?
    I've looked through the manual but cannot really understand the instructions?
    Thanks for all your help!
  • rkienzle Sep 16, 2008
    How do you get the bottom case apart? I've removed all the screws I can see but something is still holding the keyboard/top to the bottom cover.
  • 446 Answers
You will find small end rubber ( round flat) that is on the top 4 pcs and the bottom 2 pcs, remove this and keep this for a while, then remove the screws that goes along w it.
from there you can find out how to remove the LCD
hope this helps
Posted on Aug 01, 2008
  • ariel santos
    ariel santos Aug 02, 2008
    yes thats the one...
    goodluck dont wory its not that difficult
Tighten hinge on presario 700
There are no adjustment available to tighten the hinges on a laptop. They need to be replaced.
These WEB site will assist you in replacing hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/b>Laptop repair infohttp://www.laptoprepair101.com/
Mar 28, 2012 | Compaq Presario 700 470024-192 Notebook
The screen is floppy on my Compaq Presario CQ70 and needs tightening can you inform me on how I can resolve this please ?
Check the screen mounting screws on the back of the laptop near the hinges, make sure they are tight.
If these screws ar tight and the screen is loose then the hinges need to be replaces because there are no adjustments available to tighten them.
Replacement hinges may be available from one of these WEB sites.
LAPTOP PARTS
http://www.nylaptopparts.com/
www.laptoprepairco.com/
www.laptopparts.com.au/
www.laptopking.com/
www.lappy.com.au/
www.excelcomputerinc.com/
www.laptoprepairparts.com/
www.lapzone.com/servlet/StoreFront
www.laptoppartsexpert.com/
www.sparepartswarehouse.com/
http://www.sparepartswarehouse.com/
Jul 14, 2011 | HP Compaq Presario CQ70-120US Laptop
How to remove the screen of compaq presario cqm60
Basically the LCD screen is attached to the bottom of the laptop by the hinges. This may require the keyboard to be removed to get access to the LCD connector to the motherboard. The hinges may also be secured by screws at the back of the laptop.
Oct 01, 2010 | Compaq Presario CQ60-220US PC Laptop
The bottom half of my screen is black with colored lines?
More than likely this is screen failure, but to be sure, removed the bezel from the lcd and remove the keyboard so you can visually look at the lcd cable connected to the motherboard. I would like you to loosen the lcd from its hinges, there are tiny screw running up the sides of the lcd, these hold the screen to the hinges. Tilt the screen toward you so that you can access the back of the screen. There is a flat cable running up the back and plugginh into a socket near the top edge of the screen, make sure this is fully seated in the socket. Loose connections are the only otheranswer to this problem you have, if the cables are secure, your lcd has failed and needs to be replaced., Below is a link to the service manual for that model laptop.....
http://h10032.www1.hp.com/ctg/Manual/c00753552.pdf
Nov 27, 2009 | HP 435768-001 - Compaq Presario C300...
I had to replace the hinges on my c300. the screen worked before i unpluged everything now i only see a faint screen. any suggestions
Sounds like a backlight inverter issue. Perhaps during the repair the wires disconnected or there was a short circuit. You should look for improper connections from the display. If every connector is ok, then maybe you need to replace the inverter.
Sep 07, 2009 | HP 435768-001 - Compaq Presario C300...
My Presario 300 has two broken hinges
Yes they can. You can buy new, or look on Ebay to see if any are available.
You have to remove the LCD Screen Bezel, LED Cover, (Switch Cover), and the Keyboard to access both hinges.
Sound like I'm typing a foreign language? Let me show you a guide to replacing those hinges, complete with photos, so that you may better understand,
This is a PDF file download for a Compaq Presario 305. After you click on the link, give it time to fully download before looking through it.
Here is the direct link,
http://www.elhvb.com/mobokive/edwin/laptops/Compaq/Compaq%20Presario/Presario%20305.pdf
If that doesn't work for you, here is the page it came from,
http://www.elhvb.com/mobokive/edwin/laptops/Compaq/Compaq%20Presario/index.html
It's in the right column. -> Presario 305.pdf
Start with Page 18, Preparing For Disassembly
Read and view Pages 24, 25, and 26. These pages show you the three connectors that must be disconnected, Display Panel cable, Inverter cable, and Audio cable.
(Pay special attention to how a ZIF connector comes apart. It's real easy to do, believe me. Page 23 shows you. You'll see that the ZIF connector is made up of two parts. The main connector body, and cable guide. The guide is shown in an up position in the illustration. It is down next to the main body of the connector, when you start. The guide does not come out all the way. You merely lift it up with your fingernails to the position shown, and the cable slides out. To replace, insert the cable in the correct orientation, then push the guide down against the main body)
Removing the keyboard is on Page 37. Removing the Switch Cover is on Page 40.
Removing the Display Panel is on Page 42.
Don't let this task seem that daunting. You CAN do it! I advise using a clean egg carton for the various screws. Label each egg holder for where the various screws come from. (Sounds pretty techy, huh? lol! That's what I use!)
Jul 02, 2009 | Compaq Presario M2000 Notebook
Compaq Presario V4000 (v4118AP) right hinge broken
I had the same problem, they are very easy to fix, I did a search earliar and found some on the link below.
http://www.pchub.com/uph/laptop/291-29919-6327/Compaq-Presario-V4000-Series-Hinge.html
You do not need to dismantle to base, you have some star screws under the battary and one either side that loosens the small panel near the screen (where the power button is). The screen cover has screws under the plastic covers then just unclips, be gentle. after that it is self evident
Aug 06, 2008 | Compaq Presario V4000 Notebook
Compaq presario 1200
there are plastic covers over the hinges, which may be part of the faceplate. being a compaq the hinge screws are most likely torx head screws. compaq used to make a special tool for removing the plastic covers on their laptops. the tool was a bar with a piece of fiberglas circuit board embedded in it. you insert the circuit board into the groove between the top and bottom covers and twist. this is, of course after removing all of the cover screws. some of the cover screws on the display may be hidden under rubber bumpers.
Jun 28, 2006 | Compaq Presario 1200XL104 Notebook
Compaq Presario M2000 Notebook Logo
208 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
