WHEEL LUG TORQUE SETTINGS ISUZU FTS 4X4 - Televison & Video
    Brigadier General:
  • 8,909 Answers
For 2000 model year, check lug nut washer for correct torque setting. ... Isuzu. Ascender, 2003-05, 80 ft-lbs. Amigo, 1992-94, 85 ft-lbs
Posted on Mar 16, 2011
What is the torque setting for my alloy wheels?
Your torque spec is usually based off of lug diameter, if you have 19mm lug nuts then 75#ft should be sufficient.
Aug 09, 2014 | 2007 Renault Scenic 1.5
Lug nut torque chart
Here's a handy link to the wheel nut torque settings for hundreds of different vehicles.
Look your's up........and away you go!
http://www.discounttiredirect.com/infoCenter/infoWheelTorque.html
Jul 30, 2014 | 2004 Pontiac Montana
1999 For Explorer XLT , 4.0 liter SOHC, AWD 4x4 , the front right wheel wobble's at any speed
Could be loose lugs/ not torqued to spec. , bad wheel bearing, bad ball joint(s), bad steering arm joint, bad rack and pinion power steering unit, or other steering components. Check lugs first, loosen and retighten while slightly jacked up to take some pressure off of the wheel use a torque wrench set to 100 ft lbs. Then raise wheel about and inch off the floor, use a crowbar to pry up on the wheel several times while observing your ball joints for excessive movement. Very much play at all, replace ball joints, works better to replace them as a pair, top and bottom. If OK, raise wheel a bit further, and grab the top and bottom of the wheel and push/pull in and out to check for play in the wheel bearing. Pretty much any play, replace wheel bearing. If ok, do the same with a side to side motion while observing the steering control arm. Look for play. Play in the joint, replace joint. Play in other steering components, replace suspect component. That's about all the stuff could make the wheel wobble unless the rim itself is bent.
Jul 22, 2014 | Cars & Trucks
What is the Gross Combination Mass of a 1995 Isuzu FTS 700 4x4
Each vehicle is different depending on exact specification, the info will be on a metal plate on the vehicle.
Mar 13, 2012 | Cars & Trucks
My 1999 Isuzu Rodeo 4x4 four wheel disk rear wheels will not come off even without the lug nuts, why?
Because the wheels are corroded to the hub, causing it to seize. Leave one nut threaded on just a few turns (so your wheel doesn't go flying), get a big hammer and hit the inside of the tire with a good solid shot. That wheel will break loose pretty quick. Good luck!
Nov 06, 2011 | 1999 Isuzu Rodeo
I have a 1999 Isuzu Trooper and when I hit the auto 4 wheel drive button it blinks and doesn't engage. The 4 wheel drive works fine. Any ideas what the problem maybe??
While driving, apply the foot brake and press the 4x4 button. If it engages, it can be bad auto locking hubs, or a bad torque converter. This is the same problem I am having right now but I was able to the get the 4x4 to work by doing what I described above. I am going to take off the wheels and check the hubs and eventually work toward the torque converter. I'll keep you updated.
Jan 28, 2010 | 1996 Isuzu Trooper
2004 silverado 1500 4x4 wheel lug nut torque
140 ft/lbs on the regular trucks, 175 on HD's with 5/8-18 threaded lugs on Duallies. no mention is made of a seperate setting for alloys.
Jun 14, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Front Hub Bearing Torque specs to complete replacement
THE LUG NUT TORQUE SPEC - 140FT/LBS\
CALIPER MOUNT - 80FT/LBS
CALIPER BRACKET 129FT/LBS
AXLE NUT 177FT/LBS
Apr 24, 2009 | 2003 Chevrolet Silverado 1500
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
