Check the screen voltage. Adjust it to a little lower and check. Check the supply voltage to its video output stage [CRT base card]. If this voltage is less than normal, this kind of fault can occur. Check the smoothing capacitor [the electrolytic capacitor of low capacitance value] is bad. If it is bad, the voltage stated above will go low,and the retrace lines will be visible. Check these.
The fault you now see is technically called vertical retrace lines with picture. The above said are the main causes for this.
If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
