Question about GrandView Classic Tripod Projection Screen Projector Screen
I am looking for the remote for classic projector screen for5X7
  • 8,457 Answers
Try website like Remotes.com to buy.They have the most of the old and new remotes for all the electronic devices.
Posted on Mar 16, 2011
Projector only in stanby mode does not switch on
This projector provides two different remote control codes; the factory-set, initial code (Code 1) and the secondary code (Code 2). This switching function prevents remote control interference when several projectors or video equipment are operated at the same time.
When the projector is operated in "Code 2," both the projector and the remote control must be switched to "Code 2." To change the code for the projector:
Select either "Code 1" or "Code 2" in this Setting Menu.
To change the code for the remote control:
Press and hold both the MENU and IMAGE buttons together for more than 5 seconds. After changing the code, make sure the remote control operates properly.
Remote control
Press and hold MENU and IMAGE buttons for more than 5 seconds.
You can change the brightness of the screen.
High ...... Brighter than the Normal mode
Auto ...... Brightness according with the input signal
Normal ... Normal brightness
On start
Note:
•When different codes are set on the projector and on the remote control, any operation cannot be made. In that case, switch the code on the remote control to fit the code on the projector.
•If the batteries are removed from the remote control for a long period of time, the remote control code will be reset.
Mar 12, 2013 | Office Equipment & Supplies
Is there a way to setup my universal remote for my dell 2400mp dlp projector? if so what is the 4 digit code?
You need a learning remote as most "universal" remotes don't have the codes pre-programmed for projectors. The Logitech Harmony is worth it's weight in gold, and it looks cool, but will set you back about $100. There are cheaper learning remotes, and they may suit your purpose better, look on New Egg and Ebay.
Jul 02, 2011 | Dell 2400MP DLP Projector
Can switch between laptop screen or remote projector screen using FN F8 but it won't display on both at the same time. It is either the laptop or the remote projector screen but not both.
Depending on your OS the exact directory would be different but what you need to do is go into your personalization settings, find the setting for your screen (same place where screen resolution is) and then click the tab for an additional monitor. There will be either a tick box or a slider that allows for the function, either pc as primary or external screen as primary and the last function should be "mirrored". I believe that is what you're looking for.
Jun 08, 2011 | Computers & Internet
The image projected is squished
It sounds like your input signal is in 4:3 and the projector is in 16:9.
You need to adjust the "Resize" mode.
On your remote, press the "Resize" button (bottom-right of the remote, looks like a screen with two arrows pointing left and right [< >]) until it is in "Normal" mode. If that does not work, try setting it to "Border".
Mar 13, 2011 | Sharp XR-10S DLP Projector
My dell d630 laptop wont recognize my infocus lp70+ remote control and I can't advance my powerpoint slides with the remote control
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
How to use a wireless remote for an optoma projector?
You just need to point it at the projection screen and it will control the projector by bouncing the beam back to it.I hope that is the answer you were looking for.
Oct 26, 2009 | Office Equipment & Supplies
Projector appears to be in lock-out (exceeding 2000hrs on bulb)
1) Press the RESET button on projector for 3 seconds or remote control TIMER button for 3 seconds and display the total lamp used time. 2) Press the RESET button on projector or remote control MENU ON button during displaying the lamp used time. 3) Select the ?0? on the screen using the MENU ( ) button or DISK PAD.
Aug 12, 2009 | Hitachi CP840/940LAMP Projector Lamp for...
Sharp XG-P25X - only white screen, no OSD, no response
It sounds like you tripped the tamper switch? Factory or authorized service center and reset via rs232 Sorry.
Apr 02, 2009 | Sharp Conference Series XG-P25X Multimedia...
GrandView Classic Tripod Projection Screen Projector Screen Logo
Top GrandView Televison & Video Experts
Electro Med Services...
Are you a GrandView Televison and Video Expert? Answer questions, earn points and help others
