Ya i can hear the fan switchin on actually it there is a certain sound that beeps when it is workin properly but now it doesnt beeps, my monitor just shows ''off mode''
    Scholar:
  • 114 Answers
Dear friend it seems that you have a problem with either a RAM or your Display Crad
Most probably with the RAM
Switch off your computer
remove the RAM and clean both RAM and the slot i think there may be some dust particles present. clean them with a soft cloth, now place it back on the mother board as you removed it
just see the slot for the cuts generall SD ram have 2 cuts and DDR ram have 1 cut a bit out of centre.
also do the same with the display card
thanks
Gagan
Is my information helpful
Posted on Mar 16, 2011
I have a 2400 monitor heater-after being on awhile it starts beeping,and wont go off until i turn it off-but wheres the heat
dust build up at the heat sink fan area.Open the side panel. blow lightly with compressed air NO air? blow through a soda straw, keep it dry
Aug 13, 2014 | Computers & Internet
Beeping sound when starting
Usually when you first turn the power on ... it's usual to hear a couple of beeping sounds . And then, you may hear whirling/clicking sounds when your disk starts up (rotating) and your CD/DVD drive starts up, etc.. Then the monitor/screen lights up and starts to show the operating system (e.g. Windows) panel ... as it starts up.
If your system just beeps ... and beeps ... and beeps... and nothing else happens, the screen doesn't light up and show anything (for a few minutes), it likely the system is not starting up properly.
If you can clarify what actually happens, maybe I can offer more suggestions/information to help.
Apr 03, 2014 | Computers & Internet
Cdc-m computer will not come on the on light works case fans comes on but that is all
Do you mean that your computer does not turn on just casing light lit on and Fan runs only? What means new, memory and case?
If just lights on, fan runs but no image on monitor or blank screen, you should hear some kind of sound form inside of the CPU casing. This is called beep code. If you hear continuous beep or 3 same beep with same length, it means your motherboard is missing RAM, just connect it properly. If does not work or stop try a good RAM installing to see the result and plug your this RAM to a working machine that have the same kind of RAM.
If you hear one long beep with two short beep After PC switching on, or Two long beep with one short beep following - that means your Graphics card is not connected properly, or damaged or miss matching. If you do not have any beep code after switching on the machine, your motherboard may not have build in emergency speaker. Try to clear this things first. Please mention details of your computer with model number of your motherboard. Let me know updates.
Jun 25, 2012 | Computers & Internet
Hp pavilion a1220n comptur will not start unplugged unit and when i plugged to back in it would not start
Do you see anything on the monitor screen? Does the tower make any beeping noise or clicking noise, or does the fan tries to start up when you power the computer on? Are the cables connected properly?
If you see anything on the monitor screen, or if you hear a beeping sound, let us know so we can diagnose further.
Aug 07, 2011 | HP Pavilion a1220n (A1220NED904AA) PC...
My Everex NC1501 stepnote laptop won't start up, i push the start button, my laptop sounds like it's about to start. There is nothing on the monitor (the monitor does not even come on), but I...
Most laptops use beep codes to isolate startup problems . You may hear something like beep beep-beep or a combination
The beeps tell you why it's not starting ... if you hear the sounds then the manufacturers web site will tell you what the code you are getting means
Feb 23, 2011 | Computers & Internet
Monitor does not light up. Computer has power.
Did you hear a sound beeping. If you can hear a sound beeping it is a RAM problem. But if there is no sound beeping that is a processor problem. Remove the processor and clean make sure that the processor fan is spinning so that it will control the temperature of the CPU to avoid overheating.
Jul 31, 2010 | HP Pavilion DV7-1232nr Notebook
Signal has gone
If the monitor comes on and displays a message like "no input signal" or something similar, it's working properly but there is nothing coming from the computer. People often think that the computer is working and the monitor is at fault, when in fact the computer isn't starting up.
When you turn on the computer, do you hear the normal sounds of the power supply fan running and the hard drive spinning? Most computers will give a beep when they turn on and the motherboard finishes some startup checks. Do you hear that? Do you ever hear the normal startup sounds that mean Windows is actually running?
If you are convinced the computer is starting and booting into Windows, I would suggest you borrow a known good monitor to use as a test. If it works, that obviously means yours is bad. In most cases there's nothing you can do to repair a monitor yourself beyond checking for loose connections, bent pins in the signal cable plug, or a damaged cable.
If a known good monitor still has no image, the computer is at fault. Either the video card or integrated video isn't working, or the computer isn't actually starting up. In any case, that's where you would need to start looking for the cause.
Hope this helps you along the way to solving the problem. Thanks fo using Fixya!
Feb 02, 2010 | ViewSonic VX2235WM Monitor
Monitor doesn't work
If it is an LCD monitor, the backlight fluorescent bulb is burned out.
Dec 25, 2008 | Samsung SyncMaster 700 L Monitor
Data is not sent to the monitor
The first thing to do is to pay attention for "beep" when your press the power button (or the reset button) to turn the computer on or reboot it. The beeps that a PC makes tells you a lot about the state of your computer. I couldn't quote for you the exact beeps to listen for, but your manual for your motherboard may tell you. Different beep pattersn tell you what is wrong with a computer.
I think for many common motherboards it is something like 4 beeps to tell you the graphics card has failed. Don't quote me, but that is at least along the lines of how it works if not the exact number.
If you're getting no display after starting your computer make sure you hear one beep. Then, listen for other activity. If you're computer has a floppy drive, listen for the 'floppy seek'. Otherwise, listen for hard drive activity. If it sounds as though there's activity along those lines but still no signal/display on the monitor perhaps check the cable between your PC and the monitor. Never hurts to just make sure the monitor is turned on of course.
If your monitor is on, and the cables are connected securely I wold restart the computer again and check for the beeps. I would be certain to count them and check the manual. Your graphics card may have failed if you hear abnormal beeps (more than one as one is usually the healthy indicator). If you hear no beeps then the PC is not even getting in as far as testing it's devices and could quite possibly be a motherboard failure.
Dec 19, 2008 | Dell OptiPlex GX110 PC Desktop
Hey wanna format ma n72
Check your Message Center Number
& Reply via same center. Keep it "NO"
Jul 25, 2008 | Nokia N70 Cellular Phone
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
