Question about Whirlpool Washing Machines
Whirlpool washing machine will wash but will stop and not drain or rinse
    President:
  • 1,796 Answers
Hi!!
In order for the high speed spinning (rinse) cycle to begin, the lid must be shut. If your unit is top load, the problem is more likely the lid switch. or the tab on the lid that activates the switch is broken. If the tab is OK, disconnect unit from power outlet, remove back panel and trace the two wires going to the switch, once located, use a piece of wire to jump the two together, reconnect unit to power outlet and set the knob to rinse cycle, if unit works, replace switch.
Good Luck!!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Mar 16, 2011
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool front loading washing machine keeps stopping before the rinse cycle. I've cleaned the filter and the drain hose as well as all the inlet hoses. It stops and all the lights flash and it wont...
While it stops to rinse , does it drain off? if not there is block on the drain valve and so there is an error on the board because the water level sensor has to switch OFF and then ON to confirm that water has come in for rinsing.
So if the cycle is absent the possible fault can be the program controller. So you need to check the actions when the fault occurs, check for drain,.then after drain the inlet valve must open to allow water and then the water flow must cut off to start the motor.
If there is no action and output then the controller can be defective.
Apr 12, 2011 | Whirlpool Washing Machines
Washing machine stops after final rinse cycle
Your lid switch is bad. It must be replaced.
Jun 26, 2009 | Whirlpool Washing Machines
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine stops at rinse cycle
Sounds like a faulty lid switch. The switch will not allow this unit to drain/spin if the switch is faulty.
Jan 05, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
