Question about Jenn-Air Ovens
I got a range top model cn200 and an'oven w198c cannot find info on your site
3 Suggested Answers
  • 117 Answers
SOURCE: kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Posted on Feb 25, 2009
Maytag317
  • 1136 Answers
SOURCE: oven does not work, but the range top will?
Hi, Are both the bake and broil elements out?You will need to test the bake element first. Sometimes the element will have bubbles in it where it went bad. UNPLUG the range and remove the 2 screws holding the element in. With an OHM meter, check the element to see if it has continuity. If the test shows an open circuit, replace the element. If the test shows a closed circuit, there could be a bad wire connection, or a problem with the thermostat/clock assembly.
The clock assembly cost is around $100.00.
It might be a good idea to call a repaiarman out to be sure.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 09, 2009
PLES389ECH F30 ERR code. Oven and stove top is locked out after trying to run self clean. The fan is still running. I have turned breaker off and back on after waiting a day and range is still locked out....
This should help, good info includes links! http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/76555-error-code-f30.html
Oct 27, 2013 | Ovens
The center clock-oven module no longer lights up and the oven doesn't work, but the burners on top work. model rf341bxk. The oven light still works. Is there a fuse blown that I can replace?
Hello, welcome to fixya.
Unfortunately many modern ranges do not incorporate fuses into the control panels, other than the 15amp outlets used for plugging in external devices, they are typically the resettable type fuse.
Many manufactures have gone away from the typically glass fuse style circuit interrupters of previous ranges of say 15-20yrs ago and older.
If the clock display is not illuminated nor functioning, but the surface element functions appear fine, it is likely a fault within the clock ( also referred to as a timer or erc ) itself. Check for possible burnt or loose wires going into the timer such as L1 or L2 etc.
**Please unplug the range or turn off the 40amp breaker at your homes service panel before attempting any service to the range**
The part for the timer/clock is # 3196967 and retails for between $167 to $233 at "searspartsdirect.com" and "repairclinic.com" respectively as I type this on June 6/2010.
Hope this info was helpful to you...even if it isn't great news. Please take a moment and rate the info I provided and thanks for visiting "fixya".
macmarkus :)
Jun 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I just moved into an apartment that has an older Caloric Prestige oven and range and cannot find the Pilot light--Please help
Hi, The caloric ranges use diferent types of pilot igniters, to avoid any further delays, I suggest geting the model number off the stove usually located under the stove's top, you don't need any tools just lift the range top(like when you are going to clean it) the model number is located usually on a metal plate in between the burners, or if it's not there , it will be inside the oven around the door liner or the oven liner. When you do locate the model, just go to the repair clinic.com website and type in the model number, follow instruction after that. see the following figure it might help in locating the model number: small_13_4.jpg
Apr 13, 2010 | Ovens
Display not working nor oven frigidaire gallery smooth top
Could be a thermal cutout or control board problem. If you can email me the exact model number at info@fixyourboard.com I may be able to help you troubleshoot the cause.
Regards,
Bruce
www.fixyourboard.com
Oct 05, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Is there a user manual for GE Gas Range JGBS23WEH4WW?
http://genet.geappliances.com/DocSearch/Dispatcher try this web site. Or go to geappliances.com, then service and support at the top of the page. Then enter your model number and it will show you the manuals you can down load for free. Good Luck
Jun 14, 2009 | GE JGRP17 Gas Single Oven
How to remove the top on a hotpoint electric stove so I can replace the burners
Most ranges attach at the rear. Just underneath the seam, where the top meets the body, there are usually 2 screws (toward the outer edge) that press 2 metal clips. Remove the 2 screws and lift up, back to front. with model info, i can give you a link to the repair manual, online.
Apr 24, 2009 | GE Ovens
I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Mar 12, 2009 | Ovens
Kenmore gas range model # 362.7121191 oven
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
My oven does not work but broiler does
Look at the ignitor. Should have 110 volts to it when on bake. Replace if not glowing. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Frigidaire 27 in. Electric Double...
Ovens Logo
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
